20 Most Recent
Philips Magnavox TP3285C 32" TV Questions & Answers
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
YEA,2ND POST!! PHILIPS MAGNOVOX 36Z500 WEIGHT IN LBS?????????????
I Apologise but I am in total shock you said that Fixya is a scam. Let me tell you something before you make a option in error, We are people we are entitled to mistakes, look first off if you do not like the experts opinion you can "rate" it there is a rating system here that halps Fixya weed out what they call BS Experts and let me tell you I do not fall into that catagory. Also if your not satisfied with the advice you do not got to pay one red dime email
[email protected] and she will reverse the charges if they feel you were given the wrong information. But Wo to you in your words SCAM I will defend this company to I run out of breath. Granted there has been some people that got there Fix and RAN without paying. Listen to this too we are not at your house, your place of business, we are not even talking to you on the phone so please provide us some respect and some patients to help you. I been a Tv repair man for 20 years tell me in DETAIL what is going on it will be free if you reply to me here, I will try my darnest to help you find a solution if not I will give you the best advise for your TV, But do not and I repeat do not disrespect and please give us patients if not I will suggest this Take you $9.99 or you $20.00 or whatever you piad and go to a repair shop were just the advice will be doubled and you HAVE to pay them or you will not get your TV back. See here if you do not like it you can reject,object...even get refunded, but for you to say SCAM you just woken up the beast of the Experts- Thank You and God Bless You!!! Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
We have a picture, but no sound. Already
If you have no audio on either the AV inputs or off-air TV channels, then it is probably in the audio output stage - the audio IC and all components in that part of the board - including surface-mounted ones - as well as dry joints/broken tracks etc. could be a possible cause. It is probably a leaky surface-mounted capacitor, transistor or diode which is preventing the audio from being produced.
This could be an expensive workshop repair, considering the cost of these parts, and the fact that SMD (surface-mount devices) are extremely tiny and difficult to replace, being soldered and glued to the PCB. This type of repair should be undertaken by a workshop - find one who give you a free quote on the likely repair cost, then you can make a decision afterwards on that basis - whether to go any further with it or not.
Horizontal grey lines and tv cuts off by itself after 10 sec
Anyshop would take this under coinsignment as a bad Horizontal IC
"intergrated circuit"
But do not shoot the messenger, its going to need a shop, I would not recommend you opening this unit and risk a fatel shock or Death. Just the flyback transformer alone could kill you. Not to sound harsh but please understand, I do not want fixya to be on the late night news that it gave someone a solution that could have caused injury or death, if your not experienced take it to a shop. You cost if it is a IC witch it sounds like to me your looking $75-$100 parts and labor.
Thanks for your intrest in fixya.com please do rate and leave feedback. Btw, I’m available to help over the phone in case u need at
Colors are distorted on the sides. Help?!?!
all colored tv has built in demagnetizer and activates everytime the tv is power on.but there are instances that discoloration of screen due to magnettic effect cannot be remove by built in demagnitizer.you can buy a separate demagnitizer for tv....to use it you need to switch on the tv .plug in the demagnitizer to ac outlet point the demagnitizer in center of the screen/front press the butoon of the demagnitizer ad move it sideways and circles as if your wiping the colors repeat it untill the color is clear.
Good luck hope this could help you..
your rate is important to me..tnx...
Turn on TV and it stays on channel 6 for 1 minute.
the problem probably on the corroded channel and volume switch tri to clean the switch with a contact cleaner...you can buy it on the electrical/electronic store...also check for any corossion at the system ic on yhe main board. there are two big ic on the mainboard one is the jungle ic or chroma and the other one is the system ic which is feets are directly connected to the channel/volume switches
clean the in between of the feets/terminal of the ic.and this will solve the problem
I try to turn the TV on but it just clicks
It can't be the fuse. Clicking indicates that the power supply is entering overcurrent protection due to a fault. Usually it's a flyback transformer or HOT (horizontal output transistor) failure that leads to this behaviour.
Turn it on,then it turns off by itself.with the remote or button
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
