20 Most Recent Philips TP3281C TV Questions & Answers
Magnavox no picture.
Faulty power supply from experience - to put it simply, something in the circuit has simply given up under load and stopped the set from working (e.g. a shorted diode/IC package). The blinking LED/standby light on the front indicates the set is in 'protect mode'. Visual inspection is a good idea - I am glad you did a little bit of that to see if there were any blown or burned components - naturally you didn't notice anything unusual (modern sets use a lot of surface-mounted parts which can cause all kinds of trouble - and are a royal pain to replace being so tiny). You could obtain a multimeter and check the diodes in the power section to start with and progress from there. Due to the complexity of modern circuitry, and the use of cheap components during manufacture, along with a lack of available spare parts these days, it makes repair somewhat uneconomical and not exactly worthwhile in a lot of cases, especially if a replacement/refurbished board has to be ordered for a specific product model and shipped to fix the problem. The only way you can get around the cost issue and be assured of quality service is if the set is currently under extended or manufacturer's warranty.
12/19/2017 11:37:02 PM • Philips TP3281C... • Answered on Dec 19, 2017
manual
manual
manual
NEED PART NUMBER
Hi
you mean the tuner?
11/27/2008 6:04:16 AM • Philips TP3281C... • Answered on Nov 27, 2008
Tv does not come on
Those are not good signs. The TV needs repair. I would unplug it and not turn it on again. If the TV is still fairly new say within five years or so, try to find a reputable repair shop. Sometimes the local Better Business Bureau may help or ask around.
9/23/2008 5:19:34 PM • Philips TP3281C... • Answered on Sep 23, 2008
Philips tp3281c chasis#32d700-7570
I believe this set has a horizontal output that has a damper diode inside. you can check inset or out, most popular is out set. take multimeter and put on ohms or continuity and touch each leg by holding one lead to end and if you are looking for a short then in continuity it will beep or zero or very ohms. And Ohms just the same way. looking for low ohms like 1.0 or 0.9 or anything close. Switching leggs back and forth. If all three legs are shorted then replace. but in this one 2 can be shorted and still be good, just depends on which ones
8/30/2007 8:19:25 PM • Philips TP3281C... • Answered on Aug 30, 2007
Philips LCD 42PFL3603D/F7 won't stay on until I've held the power button in a few times. The display comes on, then I hear a click and it shuts off. After a few cycles of this it stays on
Remove the cover on the back of the tv. Look for swollen or leaking capacitors. They kinda look like batteries. If they are bulging or leaking then that is your problem. You will have to de-solder the old ones off. Then solder the new capacitors onto the circuit board. Capacitors will cost about 20 dollars and installing them isn't that hard to do. It will fix your tv 99% of the time. So it is worth a try!
2/21/2024 9:36:48 AM • Philips... • Answered on Feb 21, 2024
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM • Philips... • Answered on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay https://www.ebay.ca > ... > Remote Controls Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ... $67.67 · ‎In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay https://www.ebay.ca > ... > Remote Controls PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost. US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com https://www.replacementremotes.com > philips > buy-... PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM • Philips... • Answered on Dec 05, 2023
ILive Sound Bar. I need the code for Philips Universal Remote to program my iLive Sound Bar please?
Best advice here https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote So many codes, good luck with that :>)
3-Digit Codes
  • 856
  • 734
  • 837
4-Digit Codes
  • 2113
  • 3175
  • 0816
5-Digit Codes
  • 33279
  • 72303
  • 32113
  • 23175
  • 33175
  • 42113
  • 31957
  • 43175
iLive remotes https://www.google.com/search?q=iLive+Sound+Bar+replacement+remote ..
11/19/2023 4:56:05 AM • Philips... • Answered on Nov 19, 2023
Needing to upgrade software on
yes i need software upgrade APPLICATION
11/18/2023 5:21:08 PM • Philips... • Answered on Nov 18, 2023
2answers
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM • Philips... • Answered on Oct 31, 2023
I need code for Philips t v using sony#rmt-d197a
The code you need to program your Philips TV using the Sony RMT-D197A is: 741
10/31/2023 3:27:55 PM • Philips... • Answered on Oct 31, 2023
I am looking to download Life View Philips software
Just to be clear, we are FIXYA, we aren't Philips, we just have a category for handy filing. The software isn't available online, just drivers. You would have to contact Philips direct. https://www.google.com/search?q=Philips+lifeview+software ..
9/24/2023 2:19:55 AM • Philips... • Answered on Sep 24, 2023
2answers
Philips 32PFL4664/F7 A parts
This sounds like a panel issue Sarah, if this is the case the set isn't repairable.
9/2/2023 9:52:08 AM • Philips... • Answered on Sep 02, 2023
Philips 3385v dvd/vcr recorder, brand new, Video plays only in fast forward
if new return it
6/30/2023 12:39:24 AM • Philips... • Answered on Jun 30, 2023
My Philips tv is just displaying setup and it's not exiting.. could anyone help out please
The EEPROM has lost it's boot log, replace the main board and the set should work
5/21/2023 12:00:58 AM • Philips... • Answered on May 21, 2023
Repair Philips 19PFL5402D/27
The ribbon cable is either loose or dirty.There could be a problem with the HDMI connections.
4/27/2023 6:19:49 AM • Philips... • Answered on Apr 27, 2023
Philips MCD716 not turning on :
You need the ribbon serial control cable to use the Phillips MCD716 to connect between the DVD player and the power amplifier. https://www.manualslib.com/manual/175139/Philips-Mcd716-12.html?page=11#manual . The power cord plugs into the power amplifier, https://www.manualslib.com/manual/175139/Philips-Mcd716-12.html?page=10#manual. The DVD player won't turn on without the control cable. Since the power amplifier only has a volume control, you can't do anything with the home theater system (change input, set the tuner frequency) without the ribbon cable. I hope this helps. Cindy Wells
4/26/2023 2:20:43 AM • Philips... • Answered on Apr 26, 2023
Televison & Video Logo
4 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
tv not come
  • Televison & Video
