20 Most Recent
LG (168HDFR014) Consumer Headset Questions & Answers
On LG tone infinim hbs900 I have a blinking blue light but won't pair to my Apple iPad ?
If the LG Tone Infinim HBS900 is not pairing with your Apple iPad, there are a few things you can try to troubleshoot the issue:
- Check the Bluetooth settings: Make sure that Bluetooth is turned on and that the LG Tone Infinim HBS900 is in pairing mode. To put the device in pairing mode, press and hold the power button until the LED light flashes blue and red.
- Check for software updates: Make sure that your iPad has the latest software updates installed.
- Check for other connected devices: Make sure that the LG Tone Infinim HBS900 is not already connected to another device. If it is, disconnect it from that device before trying to connect it to the iPad.
- Check the distance: Make sure that the LG Tone Infinim HBS900 and the iPad are within close proximity to each other. Bluetooth devices typically have a range of around 30 feet.
- Reset the LG Tone Infinim HBS900: Hold down the power button for 10 seconds, release, and then hold it down again for another 10 seconds.
- Reset the iPad's network settings: Go to Settings > General > Reset > Reset Network Settings.
- Check if the device is in pairing mode, if not activate it.
If none of the above steps resolve the issue, you may need to contact the manufacturer or a professional technician for further assistance. It's recommended to check the user manual of your device before trying any of the above steps, as the process of troubleshooting the pairing process can vary depending on the model and manufacturer.
1/28/2023 12:39:52 AM •
LG Radio...
Answered
on Jan 28, 2023
HBS-750. Why is volume low?
Take off the rubber earpieces and look down the holes to the speakers. Can't see the speakers? That is because there is a black sticker covering the hole. The sticker is actually a very fine mesh that is supposed to let sound through. But it gets clogged with earwax and other crud, which interferes with the sound. The mesh is probably supposed to protect the speakers, but what is the point if it kills the sound? I removed the mesh and my LG Tone+ sounds like new again. Maybe it will die a quick ***** from sweat and stuff, but I was going to throw mine away anyway, so even if it's living on borrowed time, I'm happy.
6/14/2019 7:57:40 AM •
LG Radio...
Answered
on Jun 14, 2019
