20 Most Recent Philips 19PR19 19" TV Questions & Answers
manual
manual
I own model #32PFL3403D/27 Flat Screen TV. I am
It sounds that the mamory IC to this TV has damaged.
9/5/2013 9:19:43 AM • Philips 19PR19... • Answered on Sep 05, 2013
2answers
TV DEAD
On some models the reset is unplugging for a minute or two and plugging back up. Otherwise you have a blown fuse where the power goes in. If you decide to replace the fuse do no go over 5 amps. If the replacement fuse blows there is a short in the set and needs a repairman.
4/16/2013 2:43:25 PM • Philips 19PR19... • Answered on Apr 16, 2013
0answers
No colour
Be the first to answer 1/12/2013 6:02:45 AM • Philips 19PR19... • Posted on Jan 12, 2013Be the first to answer
Only showing about1/8
The vertical scan output section to your TV is faulty. Contact any experienced service technician. The work is a skilled one.
8/21/2012 2:01:21 PM • Philips 19PR19... • Answered on Aug 21, 2012
HOW TO REPLACE VERTICAL CHIP/TRANSISTER ON 19
Open your TV/s back cover. Pull out the printed circuit board. Place it at a convenient position. Locate the vertical output section. Locate the vertical output IC. Desolder it out from the board. Replace a good one in place. Solder all its solder terminals. That is all.
8/21/2012 6:12:03 AM • Philips 19PR19... • Answered on Aug 21, 2012
2answers
I can't get the TV to input to watch my cable.
Most tvs won't let you switch to imput without the remote, you could try looking under the menu on the tv but if it not there then I would suggest you buy a universal remote. Or a lot of cable remotes allow you to program them to the tv.
6/9/2012 2:37:21 AM • Philips 19PR19... • Answered on Jun 09, 2012
2answers
After Power outage - picture is larger than screen
This TV also should have similar facility like 19" Tv. Try the menu, it may be in different name or classification. I do not suspect circuit fault. If you can access service menu code you can try. Better take assistance from service center. If you access service menu, do not for get to note down the values in each and every step.
4/24/2011 11:35:50 AM • Philips 19PR19... • Answered on Apr 24, 2011
Theres no brightness setting in
Hello
You can adjust the brightness control on your 19PR19 Philips Tv. For that you have to go to picture contol menu
Do it as follows
To adjust your TVs picture control, select a channel and follow these steps.
[1] Press the Menu Button on the remote control to display onscreen menu.
[2] Press Cursor up or Cursor Down button until the word Brightness is hilighted. For each press of Cursor Up or Cursor Down button you can go through Colour, Picture, Sharpness, Tint, Colour temp etc, depending on the adjustment you want to make.
[3] Press Cursor right or Cursor Left buttons to increase or decrese the selected option. Ok.
1/30/2011 10:12:14 AM • Philips 19PR19... • Answered on Jan 30, 2011
Do you know the code number of a vista
the remote code is 5986
1/18/2011 9:13:53 AM • Philips 19PR19... • Answered on Jan 18, 2011
My 19pr15 c122 will come
It's seldom the parts that cost much, it's the labor to figure out which parts are causing the trouble that make TV repairs expensive. Many things can cause a TV to behave the way you describe, so I can't point out one or two specific parts. Even if I knew exactly what was causing the problem, you might have trouble getting the parts or lack the tools and soldering skills to replace them. It's possible to do more damage trying to repair a set without some experience. So while it's certainly fixable, it's probably not economical for this small of a TV. You could easily replace it for the same cost you'd likely face if you have a technician service it. Use this as an excuse to find yourself a new TV.
1/1/2011 11:34:22 PM • Philips 19PR19... • Answered on Jan 01, 2011
SOURSE PROBLEMS
What do you mean by this "Source problem"?
Give us details.
10/15/2010 7:47:32 AM • Philips 19PR19... • Answered on Oct 15, 2010
I am trying to hook up my Philips 19PR19 (made in
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
4/7/2010 4:25:38 AM • Philips 19PR19... • Answered on Apr 07, 2010
Lost remote for 19PR19. how can i get
Well you can please follow the below link to purchase your remote -
http://www.remotecontroldepot.com/servlet/the-1098/Philips-RC282901-fdsh-04W-Remote-Control/Detail
or
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290416817633&rvr_id=&crlp=1_263602_263622&UA=WXO%3F&GUID=d2d954741260a02675148004ffa8c5cb&itemid=290416817633&ff4=263602_263622
Good Luck!!
3/28/2010 7:01:10 PM • Philips 19PR19... • Answered on Mar 28, 2010
Trying to hook up my wii to an very old model phillips magnavox
I think you have two options here:
1-Maybe your TV aux input is the type where the AUX channel is before channel 2, or after whatever your highest channel number is. If so, you can access that AUX channel by either going channel UP or channel DOWN.
2-If that doesn't work, maybe it's worth the $5 for a cheap universal remote, that you can program, and thereby access the TV INPUT mode.
Hope this helps.
3/6/2010 3:55:59 AM • Philips 19PR19... • Answered on Mar 06, 2010
Philips 19PR19 19" TV Logo
40 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
know code number vista
  • Televison & Video
