20 Most Recent
Philips 32PT5441/37 32" TV Questions & Answers
Philips standby light keeps blinking
How many times it blinks at a time.
Visit the site named 'Electro-help' for
more details. Click this link. View it in
'Flip card' option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. Some times, the ads attached with each
posts, both at the right and bottom, might help you to find the availability of
spare parts. There are more than 900 posts to different brand TVs now. Pull up older posts there.
10/3/2012 2:40:23 PM •
Philips...
Answered
on Oct 03, 2012
Turn off captions
Go to menu, use channel up/down to move across, volume up/down to select to turn off caption.
11/13/2011 7:54:44 PM •
Philips...
Answered
on Nov 13, 2011
32pt5441/37 TV shuts off after
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Good luck in solving the problem...
8/9/2011 11:38:31 AM •
Philips...
Answered
on Aug 09, 2011
No color picture, control menu
I have a question just for clarification only.
1. Do the symptoms does not appear before or its a new set?
2. Do the symptoms also appear in other inputs (video mode)?
Let me know to assist you further...
Jdvillanueva
5/24/2011 4:03:10 AM •
Philips...
Answered
on May 24, 2011
I tried connected my XBox
In many cases there is nothing wrong with the TV. You may need to reread the handbook for operating setup on picture centering in the Xbox instruction book. In some rare occasions you may need to upgrade the Xbox with a USB upgrade connection. Thanks for asking and show a few hands of support!
11/7/2010 2:58:35 AM •
Philips...
Answered
on Nov 07, 2010
I have a Philips TV
This was a common problem for these tv,s. The tv is getting to hot it sounds like and that is why it comes on and then off right away. The tv is made to shut off if it sense something wrong like, over heating, something goes out and the tv knows so it shuts it down as well. That could be alot of problems to find out the wright problem you might need schematics for that tv. The tv is putting out a code as well right? The code that you mentioned might tell it for you. Enter the tv and model number in your seach provider and it will come up with a little searching on the internet your blinking problem.Thanks
10/7/2010 4:37:51 AM •
Philips...
Answered
on Oct 07, 2010
Picture darkens automatically at random times
go here and complain-if enough of us complain they will do something-this unit shgould not fail after a few years of use
http://www.support.philips.com/support/contact/contact_us.jsp?userLanguage=en&userCountry=us&contactId=PU_US_1_3&weekDay1=Monday%20-%20Saturday%208:00%20AM%20-%2011:00%20PM%20EST&weekEnd1=Sunday%209:00%20AM%20-%206:00%20PM%20EST&_dyncharset=UTF-8
2/17/2010 1:03:54 AM •
Philips...
Answered
on Feb 17, 2010
When I turn the tv
Bad capacitor in the high voltage circuit Look near FBT flyback Transfomer 100uf 160v ,100uf 100v, and resolder pinns on FBT
12/21/2009 6:11:32 PM •
Philips...
Answered
on Dec 21, 2009
Stretched screen
too wide is an HOR fault,could be a faulty cap or an bably soldered joint.
7/29/2009 1:29:46 PM •
Philips...
Answered
on Jul 29, 2009
Color loss (but onscreen displays in color) - DIY repair?
your description was great, thank you
there is only 1 hope for you on this one, intermittent color is a touf one, tap on the board with wooden or plastic handel see if you can make the color come and go that way, if so you have a intermittent break in the board, my guess is by one of the big ic chips on the board. if not able to make the problem act up with the taping then you have to look at the croma section and color oscillator section , this is not easy needs skiz and a scope and a little know how. depending on what they need for time a shop would charge 100-210 to fix this kind of problem. sorry this is not what you wanted to hear but is one of the tufer problem to fix on a tv.
5/13/2009 2:57:58 AM •
Philips...
Answered
on May 13, 2009
Colored Lines Destorted Picture
I had the same problem , sent it into the shop and they said it was a capacitor . It is a $3.00 part and $75.00 for labor . But it did fix the problem . The labor charge was inflated I'm sure so if you someone who can do it and just get the part ,would be the way to go.
4/14/2009 8:29:52 PM •
Philips...
Answered
on Apr 14, 2009
