20 Most Recent Philips 42PF9630A 42 in. Plasma Television Questions & Answers
I had the same problem, I had to send it back to Philips to get a $900 part replaced. Thankfully I had the warranty with it.
Philips... | Answered on May 12, 2019
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Philips... | Answered on Dec 24, 2017
I have seen services offered by some box stores to "calibrate" the color on televisions. (It was not a cheap procedure.) Is there a problem with a the picture? Did you reset the tv to factory settings and you still do not like the picture quality?
Philips... | Answered on Jan 05, 2016
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Philips... | Answered on Jul 23, 2015
Clear picture but white noise and static?!!!!!. What do you say?. Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Hi, Simply attaching the cable isn't always enough. Sometimes you actually have to tell the laptop to display via HDMI or DVI onto your external monitor or it will not output any signal.
Try pressing Windows Key+P, this will change your presentation settings in Windows (What screens you get a display on and how they are displayed). Cycle through to either "projector only" or "duplicate screens" and see if you get a display on your TV then.
Philips... | Answered on Feb 23, 2015
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
Philips... | Answered on Sep 12, 2014
It could be the lower scan drive or buffer. Below is a list of parts for your TV model. This company's technicians can help you over the phone and find the part you need.
http://www.tristatemodule.com/t-Search.aspx?q=42PF9630A
Philips... | Answered on Nov 04, 2013
Sounds like the main board is faulty. No SDA - SCL signals.
Philips... | Answered on Apr 25, 2013
Philips 42PF9630A 42 in. Plasma Television Logo
344 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
2006 42 plasma blank
  • Televison & Video
