20 Most Recent E-Machines W3050 PC Desktop Questions & Answers
My E-machine W3050 does not wake properly from
Question: Did it ever work? Is it only recovery from sleep? Will it boot normally if you unplug the computer while it is on (forced crash) and then restart. Will it boot in Safe mode? Getting stuck at the welcome screen indicates a driver not loading properly. Since the display does not work, likely the video drivers. Update with the newest driver from Nvidia for your system. Windows XP has had problems in the past with recovering from power management settings like hibernate and sleep. https://www.geforce.com/drivers
11/14/2017 5:21:24 PM • E-Machines W3050... • Answered on Nov 14, 2017
5answers
RELOADED XP
yes, install new drivers, ****.
12/25/2013 9:36:51 PM • E-Machines W3050... • Answered on Dec 25, 2013
USB WON'T WORK ON EMACHINES W3050
  • Verify in BIOS the devices are enabled
  • Verify in device manager there are no driver problems and the devices are not disabled
  • Open the case and verify the cables for the front ports are plugged in all the way
1/30/2013 6:28:08 AM • E-Machines W3050... • Answered on Jan 30, 2013
Registry problem
You must have an authorised (legal copy) of windows xp.Registering Windows XP enables Microsoft to notify you of essential program updates, security issues and available program patches.
Although registration is optional, you are required to first validate and activate your software to ensure that it is not a pirated copy.
Windows XP has a built-in function that will lock a non-activated genuine Microsoft product after it has run for 30 days
From the Start menu, click "All Programs," then "Activate Windows."
A blue window will appear with a picture depicting a set of keys in the top-left corner, and a message saying "Let's Activate Windows."
Click the topmost radio button marked "Yes, let's activate Windows now."
Click the white "Next" button on the lower-right corner of the window and follow the instructions to activate your copy of Windows XP.
The final blue window of the activation process will be marked "Register With Microsoft?" Click the white "Yes" button at the lower-right corner.
A new pop-up window marked "Collecting Registration Data" will appear.
Fill in the form by typing your personal details into the sections provided.
At the foot of the form you will find two blank white squares followed by messages asking whether you wish to receive special offers and promotional material from Microsoft.
Click on one or both of the white squares if you wish to participate; if not, leave them blank. Click the white "Next" button in the lower right corner of your screen.
A "Thank You" message will appear. Click the white "OK" button in the lower-right corner to complete the Windows XP registration process.
Hope this helps.
11/24/2012 6:20:27 AM • E-Machines W3050... • Answered on Nov 24, 2012
2answers
I just reinstalled XP Home
You have to use the original manufacturer Installation CD.
Among other things it contains all the needed drivers for your computer.
As a tip, when you have the yellow exclamation mark on the device manager, and also you "know" you have the right drivers loaded, rigth click on that device, and chose Uninstall.
At next reboot, Windows will detect and reinstall the device, usually with the right driver, solving your problem
Good luck
6/6/2011 2:14:13 AM • E-Machines W3050... • Answered on Jun 06, 2011
After six months sitting unused I turn it on and
This usually indicates a problem with a driver. When you say it is ok at first does it actually load in to Windows and then randomly blue screen to this error? If this is the case then there should be an "error code" that looks something like "000000000x##) where the ## is there should be a letter and a number(i.e. 1e) depending on what that number is will help determine which driver is the issue. Once we've determined the driver in question it should be a matter of reinstalling the driver in question and see if this resolves this issue.
Though the computer is a little long in the tooth and if the hardware is failing it may be more cost effective to recycle your computer and purchase a new one.
2/28/2011 6:21:06 PM • E-Machines W3050... • Answered on Feb 28, 2011
Want to upgrade graphics card for output other
Newer e-machines use the integrated graphics cards, but do not have expansion slots for anything else.
unless you have an expansion slot for a video card add on.
According to this site:
http://www.crucial.com/eu/store/listparts.aspx?model=W3050
you should be able to get an AGP 8X. This is an older card, but would be better than the intergrated one.
good luck and don't forget to vote!!!
9/29/2010 12:14:23 AM • E-Machines W3050... • Answered on Sep 29, 2010
2answers
I have a enachine w3050 computer and when i turn
it may be a problem of hard drives jumper settings and the CMOS/BIOS setting conflicts!!
first try to go to setup on pressing F2 and load optimal values and restart!!
if this does not help then open the CPU and see the hard drives jumper settings and make it to chip select(CS), and restart!
this mainly will be the problems!
reply and rate!!!
7/12/2010 12:24:52 PM • E-Machines W3050... • Answered on Jul 12, 2010
I turned it on and all that shows is a black
sounds to me like its suffering from a commen problem with the e machines the motherboard has gone and needs replacing hope this helps
7/12/2010 8:52:55 AM • E-Machines W3050... • Answered on Jul 12, 2010
I am trying to setup my wireless internet connecti...
Just insert your broadband to your computer and install the driver for it. Then open the installed program of your broadband at the start menu, all programs. Then search were the program was installed. And try to click it for the connection.
5/26/2010 3:52:30 AM • E-Machines W3050... • Answered on May 26, 2010
I recently got a e machine model w3050 as a hand
chuck it away
5/4/2010 12:44:05 AM • E-Machines W3050... • Answered on May 04, 2010
Will not turn on
Could be a bad switch or power supply, these are the first things to check besides the power cord and the outlet. You will need a voltmeter to check these things out. If you're not sure how, have someone check it out for you. I'm assuming that the power supply fan isn't coming on, so that makes it or the power switch the main culpret in most cases.
4/5/2010 4:11:01 AM • E-Machines W3050... • Answered on Apr 05, 2010
Trying to reload Windows XP on an emachine w3050
Go into bios and be sure the unit is set to boot to the DC/DVD when you boot up the unit.
clean the disk with windex - it helps to make it easier to read
4/1/2010 5:17:26 PM • E-Machines W3050... • Answered on Apr 01, 2010
3answers
What is compatible with my emahcines w3050 in
HDMI? Oh, then you would be talking about a graphics card like this one,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5071689&CatId=318
HIS Radeon HD4670 IceQ
1) AGP 8X graphics card
2) Has a VGA, DVI, and HDMI port
3) 1GB of GDDR3 ram memory
4) 128bit interface
5) 320 Stream Processors
6) Core Clock is 750MHz at maximum capability
7) Memory Clock is 1746MHZ at maximum capability
It doesn't matter that your computer system ram memory is DDR Sdram. The GDDR3 graphics ram memory operates independent of the system ram memory.
Information about graphics, graphics cards, and graphics card terminology,
A) http://www.brighthub.com/video-games/pc/articles/984.aspx
B) http://computer.howstuffworks.com/graphics-card.htm
3/22/2010 10:45:04 PM • E-Machines W3050... • Answered on Mar 22, 2010
I have a W3050 can I add a second hard drive.
yes with a double connection hard drive lead.setup 1 hard drive to master and the other to slave on the hard drive jumpers situated on hard disks.setup the master to the connection at the end of the lead and set the slave to the next hardisk lead connection down.remember to connect hard disk power leads.
10/12/2009 3:59:58 AM • E-Machines W3050... • Answered on Oct 12, 2009
3answers
No power what so ever!!
power supply could be dead in which case buy a new power supply, unless the motherboard is dead.
3/23/2009 3:15:10 PM • E-Machines W3050... • Answered on Mar 23, 2009
Computer changes background color and does not show all images
Are you able to get a screen capture of the websites you are viewing that look messed up?
It could possibly be a malware infection. Try scanning your system with Malware Bytes.
http://www.malwarebytes.org/mbam.php
regards,
Cam
3/18/2009 4:09:56 PM • E-Machines W3050... • Answered on Mar 18, 2009
Emachies w3609 3 beep codes
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer. Stuck key Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, turn the keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard. Bad keyboard Try another keyboard on the computer to verify that the keyboard has not gone bad. Bad PS/2 or AT port If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in Test all power and data leads that attach from motherboard to your hard drive IDE SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40 pin ide it will be the first to fail check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it restart your computer the found new hardware wizard should activate a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function. Hope this helps.
1/4/2013 4:27:14 AM • E-Machines W... • Answered on Jan 04, 2013
E-Machines W3050 PC Desktop Logo
Popular Tags
28 questions posted
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
W E-Machines
  • W E-Machines
Most Popular Question
after six months sitting unused turn
  • Computers & Internet
