20 Most Recent Olympus D-460 Zoom Digital Camera Questions & Answers
manual
How to install memory card in olympus d-460 camera
Follow the instructions on page 28 of the manual.
8/10/2012 11:10:10 PM • Olympus D-460... • Answered on Aug 10, 2012
How do I set the date
1. Close the lens barrier and press the LCD monitor ON/OFF button to turn on the LCD monitor.2. Press the Menu button to display the Menu.• See page 37 for how to use the Menu.3. Press the top/bottom arrows on the Jog dial to select MODE SETUP, then press the right arrow.4. Select the date order using the top/bottom arrows on the Jog dial. Press the right arrow on the Jog dial to adjust the first setting month/day/year.5. Press the top/bottom arrows on the Jog dial to adjust the first setting, then press the right arrow on the Jog dial to adjust the second setting.Repeat until the minute is adjusted.• 00 will appear for the year 2000.6. Press the OK button to save the setting. Press again to cancel the Menu.• For accurate setting, press the OK button when the clock hits00 seconds.• If the Menu button is pressed before the OK button, thesetting and Menu mode will be canceled
1/31/2012 12:18:31 PM • Olympus D-460... • Answered on Jan 31, 2012
Cannot find memory card fo
You can purchase Smartmedia 3.3 memory cards at Nextag.com, Amazon.com and eBay.com amongst others. Make sure you buy Olympus or make sure you format any other purchased card in the camera. BTW, you can purchase 128MB cards as well, not only 16 and 32MB.
Regards, Icom1
4/1/2011 9:24:06 PM • Olympus D-460... • Answered on Apr 01, 2011
I put in a new memory card but it says card full
Check the SD card is compatible with the camera - SDHC cards don't always work in older devices. If this isn't the problem, go into the settings menu of your camera and look for a "Format" option. It may also say "Format memory card". This will wipe the memory card clean, and should solve the problem. If not the card my be defective.
3/6/2011 8:19:58 PM • Olympus D-460... • Answered on Mar 06, 2011
Haven't used my camera in
It is very possible that since you stored it for along time, the old batteries leaked and the contacts are now corroded. Use a Q-tip or a pencil eraser to clean the contacts. If the corrosion was there for a while, cleaning may not help and the contacts will need to be replaced.
10/10/2010 11:04:17 PM • Olympus D-460... • Answered on Oct 10, 2010
No picture shows up and I don''t know how to go
On the back of the camera, press the button that has a square with lines in it, this is the menu button.
10/10/2010 11:00:12 PM • Olympus D-460... • Answered on Oct 10, 2010
How do you turn on
The camera is turned on when you slide the lens cover to the right.
10/10/2010 10:56:17 PM • Olympus D-460... • Answered on Oct 10, 2010
My Olympus Digital Camera D-460
Did you notice if the batteries you took out had any corrosion on them, if they did, the camera contacts probably have corrosion on them as well. try cleaning them with a Q-tip or the eraser tip of a pencil.
If the contacts are clean, you probably have a main board problem and you need to decide if you want to spend the money to repair it.
10/10/2010 10:54:56 PM • Olympus D-460... • Answered on Oct 10, 2010
Camera will not power up after battery replacement
If the old batteries leaked it is possible that they may have damaged the camera, depending on how long they were leaking before you discovered them like that, I would suggest that if the camera is still under warranty to contact Olympus if not take it to a camera store and have them check it out for you.
4/4/2010 3:11:41 PM • Olympus D-460... • Answered on Apr 04, 2010
I am trying to use my Olympus D-460 after not
Glad to hear you're back in business!
4/3/2010 8:12:59 PM • Olympus D-460... • Answered on Apr 03, 2010
I just am not able to take any pic's with my new
Was this card used in another camera before? It must be formatted in the camera it will be used in. Since this will completely erase it, be sure to download any pictures to your computer first using a separate card reader if necessary.
9/2/2009 8:11:42 PM • Olympus D-460... • Answered on Sep 02, 2009
Olympus 1050SW won't turn on after being under water...
Repair center in the Philippines
Quezon City Columbia Global Photo Sales Corporation
#129-1350, ROXAS
STREET, SFDM 1117 Quezon City
Tel: 363-8550, 363-7463
4/7/2009 8:36:24 PM • Olympus D-460... • Answered on Apr 07, 2009
4answers
I need a disc to be able to download pictures from my D-460 camer
HI,
You can download the software for your camera from
www.olympus.com
I'll let you know the direct download link in a minute.
3/22/2009 7:49:08 PM • Olympus D-460... • Answered on Mar 22, 2009
Need serial adaptor/cable
Welcome to FixYa! There are DB9 to usb adaptors at any electronics store like Radio Shack or Fry's. Also there are serial connectors that connect internally to motherboards having a COM port connection if this is a desktop/tower computer. Though he likes the camera he might like the fact that newer cameras have a much higher resolution than previously available for much less than he may have paid for the present one.
If you have any further questions feel free to post them here and include the brand/model of the new computer. Steve Medley
1/9/2009 3:50:33 PM • Olympus D-460... • Answered on Jan 09, 2009
Olympus D-460 zoom
A memory card si required in order to save images using this camera. This camera uses smartmedia cards. The size ranges from 16mb to 128mb.
Here is a website where you can purchase smartmedia cards:
http://www.oempcworld.com/OEMPCworld-com/SM.html
12/11/2008 1:41:52 PM • Olympus D-460... • Answered on Dec 11, 2008
Can I get a instruction manual in english ?
English? This is America... you'll probably have to learn Spanish.
Kidding aside, look online
http://www.nodevice.com/user_manual/olympus/digital--d-series/d-460_zoom.html
This will take you to the appropriate place and from there, Adobe reader will be your guide.
10/15/2008 5:48:09 PM • Olympus D-460... • Answered on Oct 15, 2008
2answers
"Card Full"
Try putting the card back in the laptop and formatting it FAT32 and not NTFS. Some cameras are not able to read the NTFS file system.
9/1/2008 10:26:38 AM • Olympus D-460... • Answered on Sep 01, 2008
More Space?
The memory card that your digicam needs is the Smartmedia, base on the specs i read on the net though, here is the sample pic,
http://images.google.com.ph/imgres?imgurl=http://ecx.images-amazon.com/images/I/41FYH82EBHL._SL160_SL120_.jpg&imgrefurl=http://www.amazon.com/review/product/B00004WHE5&h=120&w=100&sz=4&hl=tl&start=18&um=1&tbnid=OyDYl8_wVwp6TM:&tbnh=88&tbnw=73&prev=/images%3Fq%3Dolympus%2BD460%2Bmemory%2Bcard%26um%3D1%26hl%3Dtl%26sa%3DN
about where to buy it, I not really sure but you can try BestBuy, or nearest electronic shop. Im from Philippines. Hehehe... Try the card first before you buy it. :)
6/21/2008 2:13:18 AM • Olympus D-460... • Answered on Jun 21, 2008
Display says "CARD FULL"
have u format them in the pc and afterwards in the camera??? try it, if doesn´t work it´s a mainboard problem.
1/24/2007 6:50:21 AM • Olympus D-460... • Answered on Jan 24, 2007
Olympus D-460 Zoom Digital Camera Logo
Popular Tags
33 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Olympus Cameras
  • Olympus Cameras
Most Popular Question
cannot find memory card fo
  • Cameras
