20 Most Recent E-Machines M6811 Notebook Questions & Answers
3answers
Large PPT to video
Regarding converting ppt to video, these are many free powerpoint to video converters at:
http://www.masternewmedia.org/convert-powerpoint-to-video-guide-to-the-best-free-services/
If you are not care much about the conversion effect, you can use these tools.
If you want to get the best conversion effect that convert your presentation with all the animation, music, and videos retained, please try Acoolsoft PPT to Video.
1/22/2020 10:10:05 AM • E-Machines M6811... • Answered on Jan 22, 2020
3answers
Recovery disk error
try hiting f10 when the computer first starts up..usually there is a recovery partition on the hard disk..continually hit f10 or f12
6/27/2019 5:23:13 AM • E-Machines M6811... • Answered on Jun 27, 2019
New battery in eMachine M6811 won't fully charge.
1) Control Panel / Security & Maintenance / Recovery
2/22/2018 10:55:39 PM • E-Machines M6811... • Answered on Feb 22, 2018
8answers
We have forgot the account password and can not
Hi,Everyone mentioned some password recovery software, I too recommend you to use Stellar Phoenix password recovery software (http://www.stellarinfo.com/password-recovery.htm) . but I will advice you to first use manual methods of password recovery such as use windows installation disk or use "Offline NT Password and Registry Editor" to reset lost password.
8/14/2014 9:05:34 AM • E-Machines M6811... • Answered on Aug 14, 2014
When I turn on the laptop, I get 4 beeps in a row and it wont power up. What could be wrong?
The Emachines were running the Phoenix BIOS. 4 Beeps in Phoenix could indicate a RAM issue. It can be a simpe issue of the RAM chip came loose, and should just be re-seated. Turn your machine upside down, and locate the MEMORY cover. These can usually be removed using a small star /phillips screwdriver. Once opened remove the memory module by gently pressing outward on the retaining clips on both sides of the memory module until the memory module is released and tilts upward. Then, pull the module out of the slot.
To insert it again, hold the memory module at a 45-degree angle and insert it into the now empty memory slot. Gently press down on the module until the retaining clips click into placeor the RAM has been corrupted and you should replaced the RAM chip- it used DDR SDRAM 333MHz9_9_2012_7_26_58_pm.jpg
9/11/2012 7:57:00 AM • E-Machines M6811... • Answered on Sep 11, 2012
I have just bought the m6811 comp laptop from
One thing to check is to see if the WORPGROUP name is the same.
On your laptop, Right Click on My Computer and go to properties.
Click the Computer Name Tab and compare it with your Dells.
If it's the same then you might want to directly connect your laptop to the router and see if it can recognize it that way.
If all else fails, you can reset the router.
Hope this helps!
12/15/2010 7:33:46 PM • E-Machines M6811... • Answered on Dec 15, 2010
Hinge problem shod i send it to the India?
what can I say ...why should you send it to India???just cause one of the factory is there ?? look for a repair shop in the area..and just order the parts on eBay or on the factory site ...cause if you send it ...on your cost ..it means that it is out of warranty anyway ..and on the cost you should buy another ...so just look for a computer repair shop around your area..or better ask for someone that know how to do it among your friends ..cause I think service in US is kinda expensive ...and if the hinge is the problem (I mean a mechanical one..not a contact when you flip it ) this is not that hard to change ...there are just 4 screws for both of them ..and have to remove the cover first like in this movie...
(all you need is some that fits..or from at least a similar model )
http://www.youtube.com/watch?v=VyafN8BGS3U&feature=related
I know is not teh same model but the idea is to remove a few things to get to them and the most important is the cover that removes from the back of the screen up to the keyboard..and it is just cliped in plase for most models...
about Linux of windows 7....I will go for windows xp ..it has the most reliable system so far ....of course the 7 looks better and stuff but its hard to get drivers for elder devices...and always has issues cause its too new...
Linux....you have to understand it cause its a different concept to handle...if you just want to have it on but not to understand how it works...it is rather safest and fastest of them all..and if you get your hand of one simple to use like the one that came with the asus eee 7 ...its a choice to keep in mind...cause its a system built on linux but operates simple like a phone menu ..with desktop fast access..
4/18/2010 6:04:58 AM • E-Machines M6811... • Answered on Apr 18, 2010
Dont know administrator password
friend the solution is quite difficult but i know u can do it
u need a bootable cd of ERD COMMANDER
put it in ur cdrom and booot ur system from ur cd
after this ur syetem open a live window and u have strat option on this window
click on start
then click on locksmith tab
and now follow the steps
if u need any other help
u can call me at +91-9873811673
beetween 8 am -10 pm according to india time
4/17/2010 4:04:04 PM • E-Machines M6811... • Answered on Apr 17, 2010
Can not type on my keyboard
She may have spilt something on it. Accidental damage you could get it replaced under warranty as you get a years manufacturers warranty with the machine
2/23/2010 9:05:46 PM • E-Machines M6811... • Answered on Feb 23, 2010
I just want to download some music to my
dont download limwire go to 4shared.com
1/9/2010 1:06:54 AM • E-Machines M6811... • Answered on Jan 09, 2010
2answers
Will windows 7 work well on emachines M6811
It will work with windows 7 but it is suggested that you upgrade the ram also to atleast 2gb.
11/23/2009 11:34:49 AM • E-Machines M6811... • Answered on Nov 23, 2009
2answers
Shuts off in the middle of use for no reason
it sounds like an overheating problem there is a sensor that detect heat to stop from damaging the computer check to see if the fan is running and that its not clogged with dust.also you can try a laptop cooling pad this may help. but make sure the fan in the computer is running and uo to speed you may need a new cooling fan.if it keeps shutting down you may need to have the processor temp checked.with a infared heat sensening gun.
11/8/2009 4:09:39 PM • E-Machines M6811... • Answered on Nov 08, 2009
My emachines m6811 screen shows a poor quality
Sounds like the pc is set to a low pixel setting, try going to properties and adjust display settings.
ie. Right click on desktop image, click on Properties. WIndow will pop up, click on SETTINGS tab and adjust Screen Resolutions and/or Color Quality. That should make the change. Sometimes programs installed changes those settings. Good Luck!
7/24/2009 9:00:42 PM • E-Machines M6811... • Answered on Jul 24, 2009
Install xp w/o cd
you can try it using network boot option but for it your computer should connect with proper network (server)
3/29/2009 8:20:17 AM • E-Machines M6811... • Answered on Mar 29, 2009
INSTALL XP ON EMACHINES M6811 WITHOUT CD
If you have another pc, network the two and share the cd drive of the other PC
3/7/2009 4:57:54 PM • E-Machines M6811... • Answered on Mar 07, 2009
Button battery wears out quickly
that seem unreasonable for that machine, have contacted the manufacture about that problem or brought that to there attenition, that maybe very important to there engineers or final test people.
the are thing is looking for a switch that is government ceritified, it has to need certain standards before it can be used on any aircraft so look into a switch that has a curciut braker biult in the switch and every time it wants to burn up the curciut will trip and save the switch from being broken, if later you want to know more about that type of switch you may email me at [email protected]
ps the switch as all different type of surge protection built into it, you maybe go to airport and talk to avaion repair techs and ask about one the they cannot put back into aircraft and buyit or airplane junk yard, small airport machinic, avonics shop, now the switch will not be cheap but you will never have to buy a new switch every 2 months.
rod the candymangandy
2/18/2009 4:32:20 PM • E-Machines M6811... • Answered on Feb 18, 2009
2answers
Suddenly, my screen is dull and dim
There will be a brightness switch it will be a combination of the fn key and a key with a sun symbol and an up arrow on it (usually the up cursor key) if that doesn't work i'm afraid that your backlight or inverter has died, you can get replacement parts on ebay but if you havent done this sort of repair before it may be better to take it into a shop to do, unless you are still under warantee then the manufacturor has to repair/replace, its a good idea to get everything backed up off your Hard drive first.
double check that its the backlight by pluggin the laptop into an external monitor first as if it is a backlight issue it will display fine externally
hope that helps
1/18/2009 1:55:26 PM • E-Machines M6811... • Answered on Jan 18, 2009
How do i take my emachines m6811 laptop apart for a cleaning?
Well the company that made emachines at that time (Trigem) went bust so no support from the makers....
Best thing to do is search google for a dismantle guide or dissasembly or somthing like that...
Sorry not the most helpful answer in the world...
Matt
1/16/2009 12:42:24 AM • E-Machines M6811... • Answered on Jan 16, 2009
2answers
Slow operation
remove unnecessary programs from the startup
12/29/2008 8:33:35 PM • E-Machines M6811... • Answered on Dec 29, 2008
E-Machines M6811 Notebook Logo
Popular Tags
24 questions posted
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • E-Machines Computers & Internet
Most Popular Question
when turn laptop get 4 beeps in row
  • Computers & Internet
