20 Most Recent Philips 9P6031C 60" Rear Projection Television Questions & Answers
Phillips 51pp9303h/17 red and green
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1/30/2011 12:01:38 AM • Philips 9P6031C... • Answered on Jan 30, 2011
Colors are messed up and
This is a common problem. Your TV has a convergence failure. You can get parts and instructions from www.TvRepairKits.com .
1/22/2011 7:28:18 PM • Philips 9P6031C... • Answered on Jan 22, 2011
2answers
Picture comes on but very
Hi
Thanks for using FixYa. The issue seems to be with the convergence ICs going bad and should be replaced however; please post back your question in details so that I can further assist you.
Thanks
Rylee
9/30/2010 10:13:18 AM • Philips 9P6031C... • Answered on Sep 30, 2010
Tv picture shrinks
This is a common problem on certain models of Philips Magnavox TV sets. The most common symptom is the screen will shrink and expand over and over. After the TV heats up for a while the video will work like normal. After a few weeks or months your TV will eventually stop working and not have video. You can get complete parts and instructions from www.TvRepairKits.com
4/18/2010 2:17:44 AM • Philips 9P6031C... • Answered on Apr 18, 2010
I need help finding a protective screen for a philips 9P6031C 60inch rear projection tv
I may salvage the parts from my set if I cant fix my problem for a reasonable price. I have a projection screen for the 9P6031C, that I may sale if I cant fix the convergence on my set. The screen is in mint condition.
4/2/2009 4:37:11 AM • Philips 9P6031C... • Answered on Apr 02, 2009
My 55
Hello sdbeynon,
This usually denotes a problem in the high voltage section either trippler or the IHVT. Since this section of the Tv has hazardous voltages I would suggest that you get a TV repair technician to give you an estimate on the cost of repair.
Judging by what you described it sounds like the trippler may have a problem. Have the technician check that first, or if you have a high voltage probe here is the procedure:
1) Remove the rear of the Tv set
2) clip the ground lead of the HV probe to ground.
3) using the tip of the probe touch the input of the trippler block you should have a voltage of 20Kv - 30Kv
4) touch the individual outputs of the trippler block they should each read 20Kv to 30Kv.
If the input is not present the IHVT or the trippler is bad, however if the 20Kv to 30Kv is present on the input but not the output the trippler itself is the problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
2/18/2009 1:25:27 AM • Philips 9P6031C... • Answered on Feb 18, 2009
2answers
Picture problem
First start off by replacing the convergence IC. They are soldered into place, so if you dont know how to unsolder and solder on printed circuit boards, you should ahve a pro assist you. They start with STK and they stand up on a metal heat sink. Also you may need to check around in the sweep supply for leaky capacitors. This set is common for them but not any in paticular
12/18/2008 6:15:39 AM • Philips 9P6031C... • Answered on Dec 18, 2008
2answers
NO PICTURE
resolder the vertical output IC
10/15/2008 1:42:31 AM • Philips 9P6031C... • Answered on Oct 15, 2008
No Sound & No Picture
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
7/16/2008 4:03:44 AM • Philips 9P6031C... • Answered on Jul 16, 2008
Green light on the front that is it!!! no sound no pic.
7/16/2008 4:03:12 AM • Philips 9P6031C... • Answered on Jul 16, 2008
Philips 9p6031c no pic. no sound just green light on!!!!!!!!!!!
IC Chip went out. Check www.magnavoxhelp.com for a repair kit
7/5/2008 5:07:02 PM • Philips 9P6031C... • Answered on Jul 05, 2008
No picture no sound
most likely the horz output is blown and voltage regulator is shorted. I f you have a muti meter you could check if they are shorted that will tell me if the power supply is ok.
I beleve at this time you should be careful this is high voltage off of flyback is 30.000 volts
See if there is a local repair shop who charges cheap road calls. I think you are
looking around 295.00 to fix.
thanks DOCTOR VIDEO
5/17/2008 10:47:02 PM • Philips 9P6031C... • Answered on May 17, 2008
Color problems...
If you have some traces of blue and green but they are very weak especially around the edges and usually blue being the the worst than you probably have contaminated cooling fluid in the Picture Tubes. Its a big job to do it right and a waste of money to do it wrong (I've seen places just drain and refill, this is not the right thing to do) the CRT's must be disassymbled drained and CLEANED before re-assymbling and re installing. It will be labor intensive but probably worth it if the TV was givin to you
4/21/2007 6:18:02 PM • Philips 9P6031C... • Answered on Apr 21, 2007
Its a slight possibility that a 2.00 Part called a capacitor could be bad on the screen drive voltage source. But most likly it sounds like the Picture tubes are comming to the end of there life expectancy. If the crts are weak there is a crt rejuvinator that could possibly clean the grids off each color gun. But this is a crap shoot, as sometimes it destroys the tubes. These type of repairs are not for the handi-man or a consumer to do. There are no real user replaceable parts inside so unless your able to solder and know the HI Voltage saftey issues, you should call a pro to assist you in this repair. Good Luck
6/24/2006 7:44:54 PM • Philips 9P6031C... • Answered on Jun 24, 2006
Philips LCD 42PFL3603D/F7 won't stay on until I've held the power button in a few times. The display comes on, then I hear a click and it shuts off. After a few cycles of this it stays on
Remove the cover on the back of the tv. Look for swollen or leaking capacitors. They kinda look like batteries. If they are bulging or leaking then that is your problem. You will have to de-solder the old ones off. Then solder the new capacitors onto the circuit board. Capacitors will cost about 20 dollars and installing them isn't that hard to do. It will fix your tv 99% of the time. So it is worth a try!
2/21/2024 9:36:48 AM • Philips... • Answered on Feb 21, 2024
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM • Philips... • Answered on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay https://www.ebay.ca > ... > Remote Controls Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ... $67.67 · ‎In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay https://www.ebay.ca > ... > Remote Controls PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost. US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com https://www.replacementremotes.com > philips > buy-... PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM • Philips... • Answered on Dec 05, 2023
ILive Sound Bar. I need the code for Philips Universal Remote to program my iLive Sound Bar please?
Best advice here https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote So many codes, good luck with that :>)
3-Digit Codes
  • 856
  • 734
  • 837
4-Digit Codes
  • 2113
  • 3175
  • 0816
5-Digit Codes
  • 33279
  • 72303
  • 32113
  • 23175
  • 33175
  • 42113
  • 31957
  • 43175
iLive remotes https://www.google.com/search?q=iLive+Sound+Bar+replacement+remote ..
11/19/2023 4:56:05 AM • Philips... • Answered on Nov 19, 2023
Philips 9P6031C 60" Rear Projection Television Logo
16 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
no sound no picture
  • Televison & Video
