20 Most Recent
Elite Minolta Dimage Scan 5400 Scanner Questions & Answers
I am looking for a
Well, I have not so good news. The DiMAGE 5400 II is a discontinued product at Konica Minolta. There was never a Vista driver for it, and there is no plan to develop one as the product is no longer being sold.
Hope that's helpful.
I got my hands on
Yes, it's gone: the scanned image ends up black in only 2 occasions: either the background lighting or the sensor array has failed. In either way it's terminal, parts aren't available and you can't fix it.
White lines in negative scans
could be the component scanner inside of the minolta , it will need to be tested to determine if the scanners components or a wire strip is causing the problem or the component scanner its self , it sounds like a section of it is out so it will not see anything ------ ---------- in that section
Major jam auto feed embassy elite lf900 motor runs paper does not move
Check for Overload:
Ensure that you haven't exceeded the shredder's maximum capacity. Overloading the shredder can lead to jams.
Feed the paper in a steady and consistent manner, avoiding sudden force or crumpled sheets.
Switch to Reverse Mode:
If a jam occurs, switch the shredder to reverse mode. This will help dislodge any stuck paper.
Gently remove the jammed paper from the feed slot.
Inspect the Feeding Entry:
Make sure the feeding entry of the shredder is not blocked or jammed.
If there's any debris or paper stuck, carefully remove it.
Check the Cutting Blades and Gears:
The gears driving the cutting blades may be stripped or worn out.
If you suspect this, consider contacting technical support for assistance.
