20 Most Recent
Philips TSU3000 LCD Touchscreen Remote Control Questions & Answers
Touch screen unresponsive. Stuck in
Hi, well, in my shop, whenever we get these types of remotes and they are stuck in calibrate mode, then either the remote itself has faulted or the memory has? Until one actually tests and inspect the instrument it's pretty hard to exactly tell. Often moisture gains ingress and this will cause problems, that and the fact that remotes always suffer from "Hard use" no matter how careful one is in handling it.
The fact that you were able to upgrade is rather unusual though, and indicates at least that the unit isn't a total "Write off", however it will still need to be serviced by a professional. The very best and cheapest way to implement a solution,is to get this unit attended to by a Philips repair professional, now contact a local or head office of Philips, now ask them for a referral to an authorised servicing center. Now when in tough here,FIRST only ask for a"Quote" as to costings etc. Now when in position of this information,then one can, make up ones mind as to what to do repair or replace?
Is there any less expensive way to repair the
If your reset button is broken, remove it. The reset button has little function. It acts like a momentary battery disconnect. Removing the battery and reconnection has the same effect as pushing the button.
How do I get this working again?
Hi
Open the remote and clean it inside the sheet rubber and board with alcohol and soft brush.Dry it up and make sure there's no residue left on contact sheet and board.Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
