20 Most Recent
Toshiba Satellite L505D-S5983, L505D-S5985, L505D-S5986, L505D-S5987 Series Laptop Auto Car Adapter (C1975SUM310075F33E) Questions & Answers
Speakers keep going on n off
Try the latest audio driver...then do an audio diagnostic by going to run then type dxdiag. Hope this helps
3/10/2015 3:33:51 PM •
Toshiba...
Answered
on Mar 10, 2015
Toshiba Satellite L505D-S5983 Sorry if this is
The GPU in every laptop is soldered in place, if you have a lot of experience with reflowing then you can try to pull the GPU and replace it but a lot of the time it's actually more cost effective to get a replacement MB and sell the one that's having issues. Because the GPU may not be the only part that has gone out or it maybe another part that has gone out and is keeping the GPU from powering or outputting signals
10/29/2013 10:03:51 PM •
Toshiba...
Answered
on Oct 29, 2013
Black screen even on ext monitor
External monitor confirmation means that you're not getting anything out. If there truly are not words coming up, telling you what's up, then you're probably looking at a bad logic board. It could be bad video, but if nothing, not even a fan, is spinning up, then you're not getting power across the system. Check all your power connections and inputs, but I'm leaning towards a bad system board.
11/17/2012 3:18:58 PM •
Toshiba...
Answered
on Nov 17, 2012
My battery won't charge
There's not much that can be done except return the adapter for replacement. But first, are you sure your car's cigarette lighter works ?
3/28/2011 11:14:42 PM •
Toshiba...
Answered
on Mar 28, 2011
Microsoft Office Home 2007 was already on my
hi,
There reason is because the MS Office that is pre installed on your computer is just a trial version and maybe already expired,that's the reason why its asking for a product key. The product key that is located at the bottom of the laptop is not for the MS office but for the Operating System but I doubt that it will work on the pre installed Operating System on your computer because that is an OEM version and it doesnt requires a product key. If you want to continue using the MS Office, you will need to buy the full version of it that came with the cd and the product key.
Hope this will help...
1/18/2011 6:01:29 PM •
Toshiba...
Answered
on Jan 18, 2011
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
2 days ago
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
Toshiba Strata CHSU40A3 no display or tone
If your Toshiba Strata CHSU40A3 phone system is not displaying anything and there is no dial tone, there could be a few reasons for this issue. Here are some troubleshooting steps you can try:
- Check the power source: Make sure the phone system is plugged into a functioning power outlet and the power adapter is working correctly. You may also want to try plugging it into a different outlet to see if that helps.
- Check the connections: Make sure all the cables and cords are connected properly. If the phone is connected to a network, check the network cables as well.
- Reset the phone: Try resetting the phone system by unplugging it from the power source and plugging it back in after a minute. This will help to clear any issues with the phone system.
- Check for any damage: Inspect the phone system for any physical damage, such as cracks or breaks in the casing or any loose components. If you find any damage, the phone system may need to be repaired or replaced.
If none of these troubleshooting steps work, you may need to contact a professional to diagnose and repair the issue with your Toshiba Strata CHSU40A3 phone system.
3/2/2023 5:37:06 PM •
Toshiba...
Answered
on Mar 02, 2023
