20 Most Recent
Eva-Dry EDV300 Dehumidifier Questions & Answers
My dehumitifer freezes up shortly
This can happen if the Temperature in your room is too low. You can work around it and place a 40 watt bulb near the the inlet of the humidifier to warm up the air a bit. Also if the humidity level in your room is already too low this can cause your dehumidifier to freeze up.
Dehumidifier icecing up
Three possibilities for coils icing up.
1. Low ambient temperature in the area where dehumidifier is located. If so, shut down and de-ice it. Then move the unit to a different - (warmer) - location and start it up.
2. Heating element - (which cycles periodically to liquify frost on the coils and allow water to drain) - is malfunctioning.
3. Low refrigerant level in the unit.
Humidifier coils freeze
I believe a dehumidifier is supposed to operate in temps above 60 degrees. Even though your house is warmer than that, the air entering the dehimidifier may be getting into that range due to it being on a basement level etc. This is perfectly normal and is not a malfunction with your humidifier.
Your options are to either place the dehumidifier closer to a heat source in order to keep the air which is entering warmer. (I've even heard of someone placing a light bulb in front the unit during winter to warm the air slightly as it enters). Because the dehumidifier's coils get cold in order for it to collect moisture from the air, if they are freezing, giving the unit a rest for a few hours every few hours may allow the coils to thaw in between and prevent them from reaching freezing temperatures while running. You could use a timer to accomplish this, but you'll want to insure that it's a commercial grade timer in order to handle the electrical draw that the dehumidifier requires.
Why did my Eva-Dry EDV-2200 dehumidifier stop working? It won't turn on at all. It is just a little over one year old.
1. Measure the power supply output voltage with a Volt-Ohm-Meter. It should be 12 VDC. If no DC voltage replace power supply (I suggest NiuGuy 12 V 8.5 Amp model from Amazon).
2. If voltage is present then is the fan running? If voltage is present and fan not running then replace fan with AD0912HB-A70GL from Amazon.
3. If fan is running but no water is being released then replace Pelitier Module with TEC1-12705 available on Amazon.
4. The only other parts are simple switches and a fuse which all can be checked with an Ohm-Meter.
These units are very simple and easily repairable.
Best regards from an Electrical Engineer
11/20/2018 2:44:58 AM •
Eva-Dry...
Answered
on Nov 20, 2018
I have an ebac15 dehumidifier. When I moved it there was an oily liquid underneath. Why would this be?
There could be several reasons why you're finding an oily liquid underneath your Ebac15 dehumidifier:
Refrigerant Leak: If the dehumidifier is leaking refrigerant, it could result in an oily substance pooling underneath. Refrigerant leaks are often accompanied by an oily residue1\.
Compressor Issue: A malfunctioning compressor can cause refrigerant leaks and result in an oily substance accumulating underneath the dehumidifier.
Condenser Coil Leak: If the condenser coil is damaged or deteriorating, it may lead to refrigerant leaks and the presence of oil underneath the dehumidifier.
Internal Component Failure: Internal components such as seals or tubing may degrade over time, leading to leaks of refrigerant or oil.
Improper Handling During Transport: If the dehumidifier was tilted or handled roughly during transportation, it could have caused oil from the compressor or other internal components to leak.
Given the potential hazards associated with refrigerant leaks, it's advisable to discontinue the use of the dehumidifier and consult a professional technician for diagnosis and repair.
