20 Most Recent
Sanyo AVM-3658S 36" TV Questions & Answers
Can't Turn off Closed Captioning on Sanyo 36 in TV AVM-3658
Hi Hfrohman, This may sound crazy, but, press and hold the power button on the TV while unplugging it, continue to hold power button for 60 seconds or more. Release it and plug TV back in. Sometimes that will clear the settings.
I hope that works for you.
Cannot scan for channels on remote
The remote model number doesn't help directly. This remote controls several Sanyo TVs including the DP46142 and DP32242. Manuals Lib has the owner's manual (copyright 2012) here:
https://www.manualslib.com/products/Sanyo-Dp46142-77711.html . Press Menu (below and to the left of the arrow keys). Select Setup (the icon that looks like a satellite dish) using the left/right arrows. Press the down arrow and go to ANT/Cable setup. Press OK (in the center of the arrow keys). Use the left/right arrow keys to make sure that the Ant In line is set to Antenna. Press OK. Go down to Auto Setup and press OK. Choose from All Channels, Analog Channels and Digital Channels and press OK again. Select Apply and press OK when the scan is finished. (All channels and Digital Channels will work the same way since most analog channels are no longer broadcasting.) See
https://www.manualslib.com/manual/306779/Sanyo-Dp32242.html?page=22#manual . Note: digital channels will not display if the signal strength is low. You may need a different antenna or a different antenna placement. See antennaweb.org or tvfool.com for suggested station transmitters.
I hope this helps.
(note: the physical buttons on the TV should work to navigate the menu. Use the channel buttons for Up/Down and volume for left right. The OK button is the Input button.)
Sanyo amp stuck in standby mode can I pull it out this mode
When in the standby mode the 3 or 5 volt standby voltage is present for the main cpu IC to "wake up" the power supply, and put it to work, this is a signal that is introduced to the power supply when the on button is pressed, or a command from the remote, also if some components are defective and drawing to much current it won't come out of standby as well, this will require some electrical engineering skills to troubleshoot the amp, I suggest you take it somewhere to have it serviced unless you have the knowledge and test gear to fix it yourself.
Sanyo DP22640 television that has shrunk on both sides?
If you have already tried replacing the mainboard and it did not fix the issue, then the problem may not be related to the board. Here are a few other potential causes for a TV screen to shrink on both sides:
- Picture settings: Check your TV's picture settings to ensure that the aspect ratio is set correctly. If the aspect ratio is set to "zoom" or "wide," it can cause the picture to appear smaller on both sides.
- Overscan: Some TVs have a feature called "overscan" that can cause the edges of the picture to be cut off. Check your TV's settings to see if there is an overscan option, and if so, turn it off.
- Defective panel: If neither of the above solutions works, it's possible that the issue is with the TV's panel itself. In this case, you may need to have the TV professionally serviced or replaced.
It's also worth noting that shrinking on both sides can sometimes be a normal behavior for certain types of content, such as older movies or TV shows that were originally shot in a different aspect ratio. In this case, the content may simply be displaying as intended.
No power on Sanyo DP50E44 TV
There is a main fuse inside the TV on the main power board you can check. However, usually when a fuse blows, it means there is something shorted. If it just blew from a surge, you may get lucky by replacing it with the exact the same rated fuse.
How do I reset my sanyo TV model DS 1 5230
Unplug it for a few minutes, verify all of your TV and antenna connections and try again.
Verify your TV settings are set for antenna instead of cable.
If you get no signal again then you may have an issue with the input connection, inspect for damage.
How to setup sanyo dp50747 tv with no remote
If you do not have the remote control for your Sanyo DP50747 TV, you can try using the buttons on the TV itself to set it up. Here are the steps to follow:
- Locate the power button on the TV. This is usually a round button with the power symbol (a circle with a line through it) or a triangle with a line through it. Press the power button to turn on the TV.
- Locate the input button on the TV. This is usually a square button with the input symbol (a rectangle with an arrow pointing into it) or a button labeled "Input" or "Source". Press the input button to cycle through the available input options (e.g. HDMI, AV, etc.).
- Once you have selected the appropriate input, you should see the setup screen for your TV. Use the arrow buttons on the TV to navigate through the menus and select the options you want to change (e.g. language, time zone, etc.).
- To save your changes, look for a button labeled "Menu" or "Options" on the TV and press it. This will bring up the main menu, where you can select the "Save" or "OK" option to save your changes.
Note: If you are unable to navigate through the menus using the buttons on the TV, you may need to use a universal remote control or purchase a replacement remote for your TV.
