20 Most Recent
Sanyo DS19330 19" TV Questions & Answers
I added more channels from comcast...but i cant
Unfortunately you cannot access the Parental Controls without a remote you will need to get a universal one that fully supports your tv, one like
http://www.emtcompany.com/sanyo-ds19330-remote/rc64.html
HOW DO I CHANGE THE
If there is no input button on the tv, then there isn't any way to do that.
How do i change the input without a
This works on some t.v's, try pushing the two volume buttons on the tv at the same time. If it works it will bring up the menu, then you can change the input.
I have an old 2003 model B3240395925084
hi, have you tried going down the channels to 0 then press down a channel again sometimes this will then go to the video mode, if it dont then their is no other way of doing this unless you buy an all in one remote.
the good thing is these are cheap to buy now and if you live in uk any pound shop will sell you one and you can set these 2 work your telly so if changing the channels passed 0 dont go to video then the only option would be all in on remote that is unless the telly has a button on it that looks like a picture of a rectangle with an arrow running from left to right if you have this button the pressing this would give you the av mode.
have you also tried connecting the device your connecting via the av source then switch the telly on now whilst the tells is on switch the other device on at the mains and then switch it on now your telly might pick up the signal and change on its own if not the only option you have left is one of those remotes that control everything, they are really cheap to buy and would solve your problem.
let me know how you get on or if you need further assistance ok
Service Manual
For the
service manual of a Sanyo DS19330, pls try
here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Remote wont work properly
Here is a list of faults for that tv. Is recommended to take to a qualified repair shop. I could not find a recall for that set, only a complaint about a different Sanyo set that should have been recalled. Find that link here http://www.my3cents.com/showReview.cgi?id=41608 and the link for some known or I would assume common faults listed for quicker repair for Sanyo televisions. http://www.euras.com/repair_tips_1/SANYO/DS25320/DS25320_SANYO.htm
Hope this helps. Ratings are very important to us so I want to thank you in advance for taking a moment to rate my response.
Matt
Loud humming noise
this problem is sif coil & sound releted 5.5 crustal &releted pf try this
Wont turn on
Check Horiz Output transistor and we go from there...T.
Sanyo DS19730 TV No Sound
Number 1 If the Sound is Ok,(CLEAR)For 1 min,Then the First thing I would be Checking Is the Audio Output for Ringbreaks around the Conns,If you have Jacks that say audio out on the Back Plug it into to a Input of a Stero and see If that works
Sanyo TV power cord removal Model DP19649
It unplugs.https://www.amazon.com/POWER-CABLE-SANYO-DP19241-DP26670/dp/B019XGHRO8orhttps://directtvparts.com/sanyo-tv-dp19649-power-supply-1av4u20c38500-dac-12m069-2995321500/
