20 Most Recent
Sanyo DS32830H 32" TV Questions & Answers
How to know what is good or bad
What is your question? Check
this site for more
details. It has more than 1400 posts to
different brands of electronic entertainment and other equipments. All posts referrers with the repair and
fault finding to electronic entertainment equipments. It will be best to view it either in
Flipcard or
Timeslide
option, can be selected by the sidebar tag at the top left of the display
screen.
Timeslide view will be the best to select. If you are using Google Chrome as browser,
Flipcard
option will be the best. Sometimes, it might have an answer to your question.
My sanyo tv is stuck
Hi crowe,
Welcome to FixYa.
My name is John.
I will be assisting you with your issue.
Try to unplug it. Wait five (5) minutes. then
retry. Thanks for choosing FixYa.
John
Picture cuts out on 20" Sanyo HDTV
That sounds like a manufacturers fault to me, i would take them back and raise hell, in my professional opinion that just don't happen, unless there is a design failure, often sets are recalled and modified free of charge due to an occurrence such as you describe, the exact same symptoms are pretty much unheard of unless there really is a problem, get onto Sanyo head office and indicate whats gone on, you may be surprised to find there is a free fix...or even contact the local service center as they may also very well know about it and have a repair bulletin. We get them in the shop all the time, and if a customer brings in a unit with such a fault, they are often surprised to find part of the cost id covered by manufacturer..service bulletin warranty claim, usually though they must be inside warranty, but even then, most times they are reasonable,and will still fix them when put on the spot. here's hoping. All countries have differing Chassis.
Picture is to tall. it cuts off the top of the heads
It sounds like you have the image on the perspective. If you tv is 4:3 aspect ration the video source (cable box, dvd ) must be set for a 4:3. If you have a 16:9 ratio (widescreen) the soutrce should be set to 16:9..................Nevermind, Just looked it up you this TV is 4:3.
Your TV remote will have a button to toggle/change the aspect ratios of the TV. Button could be called picture/aspect/image etc. If you have an HD cable box you need to go into the video setting and chnage the aspect ratio to match the 4:3 tv.
If you need more help, please respond with more deatils.
Sanyo TV 37647
next time dont get water on it and if you pushed too hard when you wiped it that makes it worse.
NTSC50 ,V-hold,Auto Sync
Yup, this is a fairly High end model, and supports NTSC50, V Hold is automatic, H-Sync is also automatic
Picture is all black and white
This could be a tuner problem or maybe if you have cable the little tyke somehow got into the menu of the tv and switched they type of cable signal you have in your area. Try to go into the menu ,find the auto tunning feature and go through that again. If that dosent work test the cable line your using with another set at the same location. If that tells you the cables good by geting color on another set its time to call in a service person as I decsribed all the things i would hve tryed . Try the # and link im leaving here for you. good Luck. (800) 421-5013 or
[email protected]
Sanyo TV power cord removal Model DP19649
It unplugs.https://www.amazon.com/POWER-CABLE-SANYO-DP19241-DP26670/dp/B019XGHRO8orhttps://directtvparts.com/sanyo-tv-dp19649-power-supply-1av4u20c38500-dac-12m069-2995321500/
