20 Most Recent
Sanyo DC-DA1000 CD Shelf System Questions & Answers
Displays no disc when Cd is player
HelloPut it an other good known disc, which the set has played without any problem at all. If it also doesn read it, and displays no disc, the Laser Picku unit of your set has damaged. Put in a lens cleaning disc into the player, and play it for at least three times. If the fault is due to accumulation of dust or durt, the cleaning disc will clean it, and your set will be OK. If not repalce the Laser Picku Unit, sith same type and number.The lens cleanig disc can be bought from most of the electronic sparpart selling shops at your town, and won't cost more. OK.
How to set the clock on a Sanyo DC-DA1100 stereo?
This is taken from the user manual.
If switched on, press the ON button to turn the unit off.
Press the CLOCK/TIMER button for at least 2 seconds so that the clock icon blinks on the display.
Press the MEMORY button. The hours display blinks.
Turn the VOULUME control to set the hours.
Press the MEMORY button. The minutes display blinks.
Turn the VOULUME control to set the minutes.
Press the MEMORY button. The clock starts.
NOTE: the time can be set accurately by pressing the MEMORY button when a time signal is heard.
Changing the clock to 12 hour display.
When the clock is display, press the MEMORY button and hold it, then press TUN UP buttom (this will change from 24hr format to AM/PM format)
Sanyo TRC 1149 winding and playback faults
Hi,\015\012\015\012I'm sorry to hear that.\015\012\015\012This is a common fault on cassette decks and can be caused by a number of things.\015\012\015\012The most common is the motor being seized or worn.\015\012\015\012If the motor spins when you touch the belt then the problem lies in the drive mechanisms.\015\012\015\012There is a good chance that the drive belt has perished and needs to be replaced.\015\012\015\012If the deck is drawing too much current when you switch it on the fuse will blow.\015\012\015\012If the fuse is fine and the deck runs for a few seconds before cutting out then the problem could be one of the capacitors in the power supply.\015\012\015\012If the deck is more than 10 years old then it may be time to replace the capacitors.\015\012\015\012You can do this yourself if you are a little bit handy with a soldering iron.\015\012\015\012That's about it really.\015\012\015\012
