20 Most Recent
Jetway V266B Motherboard Questions & Answers
My PC with a V266B
You mean you have tried over clocking? If yes then the fan sensor and the clock speed are related. That is the reason the processor is not running and hence the coolant fan is dysfunctional. Revert back to old clock speed and it will be operational again.
CL-2 94V-0 E241819 is screened next to the
what you have is a china no-name motherboard there are alot of these floating around. I've had a couple myself from shady builders there junk
if you can identify the board using cpuid try it
if you got some skill building pc's buy a new board, ram, processor, video card, and power supply if not a new basic desktop is cheep
Booting problem
This is a known problem with the V226B motherboards unfortunately, we've seen quite a few of these (although strangely some are still perfect) and this seems to be a fault that develops with some, after some months or years in use. You may find that repeated power cycling will bring it back to life temporarily, but the only real solution is to replace it I'm afraid.
Neil
No audio
It seems that no audio drivers are installed in your system. You will get a Motherboard CD at the time of purchase of your system. In that you can find the Audio Drivers Installation files, You can directly install the audio drivers from the motherboard CD. If you face any problem please let us know that we can provide the necessary solution for that. Thanks for contacting Fixya.
No audio
hi here is the link you need just copy and paste into top of the browser
http://driverscollection.com/?file_cid=388241075640e4766a71576556a cheers where the http is just to make sure lol
Phoenix bios D686 (1999)
Go to the BIOS setup and find the Boot Seuence. Select Hard Disk first and if Hard Disk in blank, Boot from CD and install Operating System. This error usually comes when BIOS do not find the Boot Record on Hard Disk. (
[email protected])
