20 Most Recent
Jetway (V2MDMP) Motherboard Questions & Answers
My mother board is a
First make sure it works without the drive connected.
Then work trough possibilities.
The data cable - Try another one.
- Is it on one pin down or sideways?
- are any of the pins bent?
The hard drive - Is it jumpered correctly. The jumper settings are commonly marked on the drive
- If you have any other devices, like a second hard drive, or DVD, disconnect them.
-Try another hard drive.
Other drives - If any, try disconnecting them. Both Hard and CD/DVD.
- Check the jumper settings on them.
Motherboard - Try it on the other IDE connector. It might to be on IDE 0.
- If it is try the other. IDE 0 may be faulty and depending on the bios IDE1 may work.
- Are there any cards installed. If so remove them and try the drive.
Power supply -Try another one if you have one.
-If not, confirm the 5V +/- 0.25v and 12V +/- 0.5V are correct.
I think that covers it, except to try removing and installing the memory, and making sure thr modules are correctly seated.
If you are really desparate, you could also try removing and reseating the processor.
I AM HAVIG PROBLEM WITH MY MOTHER BOARD MY BOARD
try to reset bios by removing battery or by using jumper else directly move for warranty since there may be problem with graphics chipset too.
so get change your motherboard with the new one under warranty
No sound after reinstalling windows 7
Well seems that ur win7 does not have the drivers for ur jetway.. pls go to its support website & download the drivers for win7 for ur sound device
Primary IDE interface fails to load
many new motherboard does not recognize slave mode on if single ide drive connect
verify both drive set is master or not after that you attach to primary your harddrive and secondary cdrom
your reset problem is wirering connection see your motherboard manual
Fan problem
No sorry. Fans can be monitored through the bios & even set to give you an alarm when the speed gets too low but you can not increase the fan speed. You can replace it with a faster rpm fan.
Standard cpu fans run between 3100rpm to 6000rpm. It is up too you. Some creat a wee bit too much noise after 4000rpm.
Heres a few for your Intel Socket 775 Pentium 4.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1588&Nav=|c:493|&Sort=0&Recs=10
Please vote!
New jetway motherboard
the disc that came with the board contains drivers specific to that motherboard. I would suggest downloading the latest drivers from the manufacturer's website for everything that is contained on the CD.
WHY PQI 4GB MEMORY NOT DISPLAY J-I41M
If you're operating a 32 bit system, the full 4GB cannot be utilised, so around 3.5 or so will show. If it's less than 3, then you may have faulty RAM.
