20 Most Recent
Garmin Nuvi 1300LM GPS Receiver Questions & Answers
1/2 to 1 hour b-4 getting satelite
It sounds like it needs to be forced to download and use a new data set. In the data are the times etc when it should be able to see a satellite. When this gets out of date it still find satellites but more by accident. First way to try is to use the web updater and use that to try and update the needed files.This can fix it if not then you need to do do a master reset.Charge the unit up. The reset should take less than 5 minutes but can take up to an hour depending on location etc. This is going to erase any user data such as waypoints routes etc so save those off first if you want them.
- Start with the unit OFF and unplugged from power
- Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
- Continue touching and holding the lower right hand corner of the screen then power the unit ON
- Release the power button when the device powers ON
- You will see a new message: "Do you really want to erase all user data?"
- Remove your finger from the touch screen when this message displays
- Touch Yes
- If text language is not in English, this is the button on the right
The
device will now reset. Follow the on-screen prompts and then place your
device in an area with a clear view of the sky until it acquires
satellites.
I have no problem. I am behind on technology.
The QUICK START GUIDE is just one of the support documents available for your device. The full User's Manual is a better document to refer to if you are unfamiliar with basic GPS operation.
Here is a link to the complete USER'S MANUAL for the Garmin Nuvi 1300LM GPS:
http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
To view the complete Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.You can download this free at
WWW.ADOBE.COM if necessary.Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
After you read through the User's Manual, which provides much more detailed information than the brief Quick Start Guide, I will answer any specific questions you have about the device's operation.
If you like, I will also try to find some instructional videos as well which may be easier to follow and be more helpful for you.
I hope that was helpful to you, good luck and take care.
Joe.
The text language on my
Hi, Go to properties in menu and check that language is in english and click OK.
When the software was updated it must have changed. Good luck.
Garmen won't stick to dashboard
What are you trying to apply to the dashboard? if you are trying to apply the suction cup it will not work. If you are finding that the dash adapter disk will not stick even after cleaning you may have used an oil based cleaner like Armor All try Rubbing alcohol to clean the area before applying the disk.
Hope this helps!
The garmin nuvi has a shatter screen it fell down
yes they can be replaced but probably cheaper to get a new one.
Give garmin a phone call to see how much it is or sell your old one on ebay and get a bit of cash to buy your new one.
Please dont forget to vote if you liked my answer
thanks
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
My garmin nuvi says system sofeware missing
Download Garmin Express from Garmin and install to your PC. Plug your GPS into your PC, Garmin Express should identify your GPS and give you options to update maps and software.
How do I turn on my Garmin Nuvi?
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If the GPS does not power on (it should go into usb mode), then contact Garmin for warranty work. You can also check the power adapter in your vehicle. If the red light does not come on, the adapter either has a blown fuse or went bad, causing your GPS battery to be discharged. It is quite possible that your battery is discharged. You might leave it plugged into your PC overnight if the battery is dead.
How do I fix the backlight of my garmin 3205
The LCD display contains both the display and backlight. They are integrated as one piece. Therefore the entire display needs to be replaced. The backlight connections are soldered to the LCD connections. Replace the entire display.
Call 1-8O5-225-669O GPS/GARMIN Update-Install-Download-Fix We are 24 Hour Available Call Now For Help Number
When encountering errors such as "No Map Data Available" and Garmin Express does not recognize your Garmin nuvi, check to see if your Garmin nuvi is out of storage space from your computer. Solution related to the fact that when brought up as the E: drive in windows there were 0 bytes free space on the Garmin nuvi. To get Garmin Express to recognize a unit which is full, do a search on the Windows Drive (E:) for "gmap" then choose "Open file location" This will get into the hidden ".system" directory. From there, delete the largest file map, such as "gmapprom" (or move this file to your hard drive). Afterward, reboot your computer to have Garmin Express software recognize your Garmin nuvi. On older units, also purchase a microSDHC card to be able to store the newest maps, such as the US & Canada 2.6Gb map file, which will not fit on the internal unit alone or a 2Gb card. The Garmin Express software will recognize 4Gb to 32Gb microSDHC Class 10 or UHS-I cards formatted to FAT32 and install the newest maps automatically to them. Some have reported that 4Gb cards are not large enough. I had used a 16Gb SanDisk Ultra PLUS UHS-I card ($10.88 Walmart) successfully on my Garmin nuvi 1450LMT
My garmin nuvi 2225 will not acquire satellites since I brought it to Europe. I loadd maps for the area but it can not find its position.
If the garmin can reach satellites in North America, it will reach satellites anywhere in the world as long as it has a clear line of site to the satellites. Depending where you are, the satellites can be higher or lower in the sky. This means that the garmin in your vehicle may not be able to see the satellites how you have it positioned in your vehicle. Try finding the satellites outside of your vehicle while in Europe. If you can, then the problem is positioning in your vehicle. The satellites are all the same kind no matter where you are.
Garmin nuvi 2225 will not acquire satellites in Europe. Worked fine in North America. I loaded maps for Europe but no action.
