20 Most Recent Polaroid Photo Media Backup Device CGA-02540B Hard Drive Questions & Answers
Cannot view STF file format
there are many free online converters on the web. Convert the file from STF to JPEG, GIFF etc.
1/27/2014 5:21:38 PM • Polaroid Photo... • Answered on Jan 27, 2014
Polaroid PSD-822 Binoculars. Hello. I really need help finding the USB lead for it?
Question edited for clarity. make model (what is is)' first. $39 and you get some free accessories! :>D https://www.cafr.ebay.ca/itm/203263611820 Take it to a components electronics store. https://www.google.com/search?q=polaroid+psd-822+binoculars+usb+lead ..
11/11/2023 8:23:24 PM • Polaroid... • Answered on Nov 11, 2023
Install Roku on Polaroid TLA-04011C displays error code 003
  1. Check your internet connection: Make sure your device is connected to the internet, and that your Wi-Fi network is working properly.
  2. Restart your Roku device: Try unplugging your Roku device from the power source, waiting a few seconds, and then plugging it back in.
  3. Update your Roku device manually: Go to the Settings menu on your Roku device, select "System," and then select "System update." Choose "Check now" to see if there is an update available, and then follow the prompts to download and install the update.
  4. Factory reset your Roku device: If none of the above steps work, you can try resetting your device to its factory settings. Go to the Settings menu, select "System," and then select "Advanced system settings." Choose "Factory reset" and follow the prompts to reset your device.
If none of these steps work, it is possible that your Roku device is malfunctioning and may need to be replaced.
2/14/2023 3:29:47 AM • Polaroid... • Answered on Feb 14, 2023
2answers
My Polaroid smart tv isn't recording things showing in scheduled list
  1. Check the storage capacity of your USB drive. If it's full, free up some space or use a larger USB drive.
  2. Check if the USB drive is formatted correctly. It should be formatted in a file system that is compatible with your TV.
  3. Make sure the TV is set to record to the correct source (USB drive).
  4. If the TV is still not recording, try restarting the TV and the USB drive.
  5. If the issue persists, check for any firmware updates for your TV and install them if available.
  6. If none of these steps resolve the issue, you may need to contact Polaroid customer support for further assistance.
Keep in mind that the exact steps to resolve this issue may vary depending on the model of your Polaroid smart TV.
2/8/2023 8:39:26 PM • Polaroid... • Answered on Feb 08, 2023
Polaroid 1521-TLUB 720p Widescreen LCD HDTV operating instructions for polaroid use as a monitor for karaoke.
Question edited for a lot more clarity. It depends on what comes out of the karaole machine. This with what the television will take. TV Type LCD Screen Size Screen Definition 720p Resolution Contrast Ratio Aspect Ratio TV Features Closed Caption, DVD Player, V-Chip Video Format ATSC (Digital), NTSC (Analog) I/O Interfaces S-Video, Composite, Coaxial, RCA, Component Enclosure Color Black Accessories Stand, Remote Control The video may help https://www.google.com/search?q=polaroid+1521-tlub+as+karaoke+monitor ..
12/14/2022 3:21:57 AM • Polaroid... • Answered on Dec 14, 2022
How to power on a Polaroid mini tower speaker
Hi there first of all does the speaker have any obvious "Power" Buttons secondly you may have a volume/on-off switch which turns the device on when you turn up the volume. some speakers can only be used with a remote lastly can i have the model number of this speaker? (should be on the back or the bottom) so i can look into this speakers manuals ETC
7/23/2020 10:44:21 AM • Polaroid... • Answered on Jul 23, 2020
How can I use my Polaroid iS126 camera as a webcam?
Unfortunately your camera doesn't have this capability
3/3/2020 2:10:29 AM • Polaroid... • Answered on Mar 03, 2020
WiFi to Polaroid tv
Try resetting the tv to default settings.if that doesn't work try resetting your router.
4/28/2019 1:46:35 PM • Polaroid... • Answered on Apr 28, 2019
Polaroid 10 Tablet freezes, Won't log on even if using reset on back or turning off & back on. Any suggestions to get it to log on. Only get the perpetual spinning circle under Polaroid logo.
You could do a factory reset. Read before you try it; you'll lose any data accumulated. http://www.mobicpc.com/how-to-hard-reset-polaroid-10-1-to-factory-default-setting.html This might give you a soft reset though it's written for the S7: Resetting Polaroid S7 is a bit tricky.
  1. Turn off the tablet.
  2. Press and hold the volume up and the power buttons together for 5 seconds then release them.
  3. You have to wait for the Android picture to show up on the screen now.
  4. Only after this screen is shown, press and hold the power and volume up buttons together for 3 seconds.
  5. Release the volume up button .
  6. Now, release the power button. You will enter the recovery menu.
  7. Now, use the volume buttons to navigate and the power button to select items.
  8. Navigate to and select "wipe data/factory reset".
  9. Navigate to and select "yes -- delete all user data".
  10. Navigate to and select "reboot system now".
  11. The phone will be rebooting . Do not press anything while that is happening until the start-up screen shows up (the one with "Make yourself at home").
5/27/2018 2:43:38 AM • Polaroid... • Answered on May 27, 2018
Polaroid Photo Media Backup Device CGA-02540B Hard Drive Logo
6 questions posted
Top Polaroid Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Are you a Polaroid Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Computers & Internet
Most Popular Question
cannot view stf file format
  • Computers & Internet
