20 Most Recent
Sharp 13VT-K100 13 in. Combo Questions & Answers
We recently had a flood in our home and my Sharp
If you Google the model number or look at:
http://www.audioreview.com/pscTelevisions/TV-VCR,Combo/PLS_2729_830crx.aspx
It shows on the above address having a msrp of $269.00
If this has helped you, I do this here for free so take just a minute and give me a vote here.
REGARDS, SD TECH
Jumping horizontal lines when connected to CD player
I want you to do a test first. Take you TV and connect a DVD player to it and see if this problem occurs. I bet you it wont, because the problem is not with the TV nor the CD of the karaoke machine. The problem is with the sync pulses of the signal from the karaoky, and the inability of the Tv to sync-up with those signals. What I would use is a video stabilizer between the TV and the DVD player.
If the TV still has the problem with the DVD player I would then check the TV for a vertical section problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
IS THIS TV ANALOG OR DIGITAL?
Hello,This set is Analog and will need a converter boxThank you,Shuttle83http://www.electron-age-technologies-llc.com
Stuck on tamper proof.....remote is lost
Greetings horsepoor2,
Yes, there are a few options for new remotes for this unit. You can find several of them at the "order parts" option found at the bottom of
www.bestbuy.com. In fact there is an option to purchase the unit that matched up directly with your television
which is RRMCG1330PESA!
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
Record one channel while watchign another
Ouirkygirl, a TV\VCR combo can only watch TV on a channel & record THAT channel. If the monitor is connected directly to the VCR then u should be able to RECORD what u see. Do you have a separate channel changer [buttons that say up\down channel ?] on the face of the VCR portion? If so, then u should be able to change the channel ON the VCR, record that channel, then change the channel ON the TV, .... I don't think so,.........any thing is possable
please explain your words :: "but when I record something it jumps to tha channel evern if I am watching something else at the time."
How can I make the text sharp on Magnavox model 22ME601B/F7?
- Check HDMI Cable Connection: If you're using an external device like a cable box, gaming console, or streaming device connected to the TV via HDMI cable, ensure that the HDMI cable is securely plugged into both the TV and the external device. A loose connection can cause intermittent resolution adjustments.
- Adjust Picture Settings: Navigate to the TV's menu and check the picture settings. Look for options related to display resolution, aspect ratio, or picture mode. Ensure that the settings are configured correctly for your viewing preferences. Try resetting the picture settings to default and see if the issue persists.
- Update Firmware: Check if there are any firmware updates available for your TV. Sometimes, software updates can fix bugs or issues related to display resolution adjustments. You can usually check for updates in the TV's settings menu or visit the manufacturer's website for instructions on how to update the firmware.
- Check Signal Source: If you're experiencing resolution adjustments while watching content from an external device, such as a cable box or streaming device, make sure the signal source is sending a consistent signal. Issues with the signal source can sometimes cause the TV to adjust its display resolution.
- Reset TV: Try performing a factory reset on your TV to restore it to its original settings. Keep in mind that this will erase any customized settings and preferences, so you may need to set up the TV again after the reset.
- Contact Magnavox Support: If the issue persists after trying the above steps, it's possible that there may be a hardware problem with the TV. In this case, it's recommended to contact Magnavox customer support for further assistance or to inquire about repair options.
By following these troubleshooting steps, you should be able to diagnose and resolve the issue of your Magnavox TV constantly adjusting its display resolution.
Hope this helps
How do I operate Sharp LCD TV remote control
First of all
1. **Power On/Off:** Use the "Power" button.
2. **Changing Channels:** Use "Channel Up" and "Channel Down."
3. **Adjusting Volume:** Use "Volume Up" and "Volume Down."
4. **Input Selection:** Use "Input" or "Source" to choose input devices.
5. **Navigating Menus:** Use navigation arrows and "Enter" or "OK."
6. **Mute Function:** Use the "Mute" button.
7. **Number Pad:** Input channel numbers or perform numeric functions.
8. **Special Functions:** Access features like "Menu," "Exit," "Subtitle," or "Info."
9. **Teletext/Closed Captioning:** Access these features if applicable.
10. **Smart TV Features:** Access smart features, apps, or online content if applicable.
11. **Batteries:** Ensure the remote has fresh batteries for responsiveness.
For model-specific details, always refer to your Sharp TV's user manual. If you provide your TV's model number, I can offer more tailored instructions.
Changing analog to digital on Sharp TV
Unfortunately, you cannot convert an analog TV to digital simply by changing settings. The transition from analog to digital involves hardware changes. If you have an older Sharp TV without a built-in digital tuner, you may need an external digital converter box or consider upgrading to a newer TV with a built-in digital tuner to receive digital broadcasts.
