20 Most Recent
Sharp Remote Control Questions & Answers
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
I WANT TO USE MY
Go to the Remote control Manufacturers website and get the instructions for the remote control. Then you need the codes for each of the items you are going to program in. You can get some of the Directv functions on universal remotes, but if it's a DIRECTV with DVR then the rewind functions, etc. may not work. Good luck!
I can not remove closed captioning on all my
As best I can tell, the TWC remote requires about 12 steps to turn CC on & off - very annoying and I can't understand why it's not simpler. Hit the blue menu button near the top; scroll down or up to Settings, hit enter, scroll down or up to Captioning, hit enter, scroll to how you want CC (off, on, or just when Mute), hit enter, then hit Exit to clear the screen. A pain, no?
Can My Comcast TV Remote Connect To A Sharp TV
the codes for Sharp LCD's are 10093 and 11602...follow the normal programming instructions but use these codes....newer remote manuals may have these codes but however the one i had didn't...hope this helps
Black and white captions
1.go to t.v. menu
2. go to close caption
3.turn it off
Toank you for useing fixya
please rate me
How can I make the text sharp on Magnavox model 22ME601B/F7?
- Check HDMI Cable Connection: If you're using an external device like a cable box, gaming console, or streaming device connected to the TV via HDMI cable, ensure that the HDMI cable is securely plugged into both the TV and the external device. A loose connection can cause intermittent resolution adjustments.
- Adjust Picture Settings: Navigate to the TV's menu and check the picture settings. Look for options related to display resolution, aspect ratio, or picture mode. Ensure that the settings are configured correctly for your viewing preferences. Try resetting the picture settings to default and see if the issue persists.
- Update Firmware: Check if there are any firmware updates available for your TV. Sometimes, software updates can fix bugs or issues related to display resolution adjustments. You can usually check for updates in the TV's settings menu or visit the manufacturer's website for instructions on how to update the firmware.
- Check Signal Source: If you're experiencing resolution adjustments while watching content from an external device, such as a cable box or streaming device, make sure the signal source is sending a consistent signal. Issues with the signal source can sometimes cause the TV to adjust its display resolution.
- Reset TV: Try performing a factory reset on your TV to restore it to its original settings. Keep in mind that this will erase any customized settings and preferences, so you may need to set up the TV again after the reset.
- Contact Magnavox Support: If the issue persists after trying the above steps, it's possible that there may be a hardware problem with the TV. In this case, it's recommended to contact Magnavox customer support for further assistance or to inquire about repair options.
By following these troubleshooting steps, you should be able to diagnose and resolve the issue of your Magnavox TV constantly adjusting its display resolution.
Hope this helps
