20 Most Recent
Chauvet Obey 70 Dmx-512 Light Controller Dj Stage Band Questions & Answers
Chauvet Obey 70 service manual
They are not worth trying to fix, if you really like this unit you can get a secondhand one for about 25GBP or find one from a decent manufacturer or even better how about a USB interface to DMX for your PC?
I have a Chauvet Obey
Remove the one just before the last one that worked and see if more work and get back to us. Also are you using official DMX cables?
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring.
This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM •
Music
Answered
on Dec 31, 2023
