20 Most Recent
Matrix Auto Chromatic Tuner Sr1050 Questions & Answers
User manual
Go to Google and type in the serial number along with the word manual and you will locate it.
Hi, i have a acoustic guitar and i am trying to
Hi
Simply turn the tuner on using the power button.
Play an open string note close to the tuner (no more than about 1/2 metre away) - for instance the low E on string 6.
The built in microphone will pick up the sound and, if your guitar is reasonably close to being in tune the led light labelled 'E' will illuminate on the lower scale on the tuner along with one of the three other leds to indicate whether the note is flat (b), in tune (green) or sharp (#).
Due to harmonics any or all of these three leds may flash but it is the one that is on the most that matters.
Adjust the tuning peg until the green is on constantly when you play the string.
Move on to the next string
Note - if the string is more than a semitone sharp or flat a different light may flash (e.g if the low E string is 3/4 of a tone flat the D light will come on).
If you wish to tune your guitar to another instrument that is not at perfect pitch (and perhaps cannot be easily adjusted - like a pipe organ) you can use the calibrate button to adjust the setting of the tuner. This temporary recalibration will be lost when the tuner is turned off.
Matrix auto chromatic tuner manual
I'm sorry, but without knowing the specific model of your Matrix Auto Chromatic Tuner, it's difficult for me to provide you with an exact manual. However, I can provide you with some general tips on how to locate a manual for your tuner:
- Check the manufacturer's website: The first place to look for a manual is the manufacturer's website. Most manufacturers provide manuals for their products on their website, and you can usually search for the manual by entering the model number of your tuner.
- Search online: You can also try searching for the manual online using search engines like Google or Bing. Enter the model number of your Matrix Auto Chromatic Tuner along with the term "manual," and you may find a PDF version of the manual available for download.
- Contact the manufacturer: If you're having trouble finding a manual for your tuner, you can contact the manufacturer directly. They may be able to provide you with a copy of the manual or direct you to a source where you can obtain one.
- Consult with a music equipment dealer or technician: If you're still unable to find a manual for your Matrix Auto Chromatic Tuner, you can consult with a music equipment dealer or technician. They may have access to the manual or be able to assist you in operating the tuner without the manual.
I hope these tips are helpful in your search for a manual for your Matrix Auto Chromatic Tuner.
4/10/2023 12:50:48 PM •
Matrix Music
Answered
on Apr 10, 2023
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring.
This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM •
Music
Answered
on Dec 31, 2023
