20 Most Recent Westinghouse LTV-27W2 27 in. HD-Ready LCD Television Questions & Answers
Audio is ine, but the screen has no blue colors. In the old days, I would have replaced a blown tube -- what is the fix now? I had previously replaced the backlight inverter in this TV last year.
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
10/9/2015 10:52:37 AM • Westinghouse... • Answered on Oct 09, 2015
Vertical color bands take the place of the picture.
I sent my question to the "solve your problem for free" on this website, so I was expecting some "free" advice. My finances are such that I can only ask for free advice. I did see someone who had a similar-sounding problem, and there was a mention of two possible main boards that would fix the problem. I was hoping to know which board would most likely fix my problem, since the TV is less than two years old. If I take it to a TV repair person, I want to have a fairly good idea how to fix it, and what would be the approximate cost, so I do not get ripped off.
5/20/2014 2:22:16 AM • Westinghouse... • Answered on May 20, 2014
I have a westinghouse Ltv-27w2 27in. HDTV- Ready LCD Television, I cant get it to come on,it came on once and had a blue screen, then went off and i cant get it to come back on, The blue light comes o
It is a little difficult to be certain where the problem is with that description, but at least statistically it is more likely to be in the power board than the main board.You can send it for repair to us or you can search for a replacement, they go about $70-$80.
10/30/2012 2:56:31 PM • Westinghouse... • Answered on Oct 30, 2012
I have a westinghouse LTV -27w2 27in HDTV-ready LCD TV,It will not come on,TV came on once had blue screen,then went off,it will not come back on,has a black screen now,blue light came on then turned
That could be either the Power supply or the main board. I would think the main board is most likely because of the Blue screen you mentioned.
10/30/2012 2:31:22 PM • Westinghouse... • Answered on Oct 30, 2012
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
10/15/2012 1:17:58 PM • Westinghouse... • Answered on Oct 15, 2012
Why are faces green on my tv
Improper color reproduction is the problem. Normally this type of problems to LCD TVs will be due to the fault to its T'Con board. But, before make it sure, re-seat all the flat cable connections that goes to LCD panel from this board.
7/10/2012 4:33:49 PM • Westinghouse... • Answered on Jul 10, 2012
Westinghouse Tv Keeps Freezing
what are you using for signal and how are you connected? Tried a DVD or Blue Ray to see if that does the same things or not?
4/8/2012 3:41:34 PM • Westinghouse... • Answered on Apr 08, 2012
2answers
I can't get my tv to stay on
Bad capicitors in power supply just fixed it in my tv
1/5/2012 2:48:44 PM • Westinghouse... • Answered on Jan 05, 2012
Manual needed for product
which product..??
1/2/2012 2:43:21 PM • Westinghouse... • Answered on Jan 02, 2012
After i turn the tv on after a while it just
I have had this problem before and found a loose connection on the power supply module on C310 next to T1 transformer. If you have soldered before you should have on problem. Just take the back off the set and the power module is the one that has the AC cord hookup. Search for C310 and remove the module via screws and unplug it and turn it upside down to the solder side of the board at the C310 location looking for the loose connection there. If you can't see it then solder it anyway and try turning the set back on after putting the board back plugged up and all. Use electronic rosin core solder and a good soldering iron that will get hot enough to do the job. If this is not the problem then suspect an open T3 in the inverter circuit. This is a transformer. T3 may be available by calling Westinghouse by looking on the internet for the manufacturer. Changing it will require using solder wick to remove the transformer and clean the holes to put in a new on. Otherwise if you cannot get T3 the whole board would need to be replaced via manufacturer or try to find on on Ebay doing a search with the model number. Also try Shop Jimmy .com or just a google search
10/23/2011 2:36:15 AM • Westinghouse... • Answered on Oct 23, 2011
2answers
Need to find code for RCA universal remote,
Go to
http://rcaaudiovideo.com/
On the left side select 'remotes' and then your remote type. You will be able to download the manual and codes for your RCA Remote Control.
Let me know if you have any other questions. Please rate this solution. Thanks.
7/23/2011 4:41:23 AM • Westinghouse... • Answered on Jul 23, 2011
I have a westinghouse ltv-27w2 and after about 15
Hi my first guess is the power supply. You can inpect it for bulged capacitors that might be obvious. My second thought is the signal board but I leaning more towards the power supply. If you want to buy parts you can find them at www.interliquidparts.com in order to get parts you have to get the part numbers from the actual part on your TV. If you open it up it has a part number stamped to it. Be carefull opening up the TV it has high voltage. leave it unplugged for a couple of hours before opening it up.
6/2/2011 10:13:39 PM • Westinghouse... • Answered on Jun 02, 2011
Westinghouse tv keeps turning off
Good day,
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic shop.
I hope this help to rectify the problem and take caution in handling the television, because it's fragile and contains high voltages....
5/13/2011 10:29:22 PM • Westinghouse... • Answered on May 13, 2011
2answers
TV just shuts off on it own...
Most likely, a number of capacitors need to be replaced in the power supply on this set, OR possibly, there is a bad connection on a connection on the snubber capacitor in the power supply, near the SMT transformer--and I have seen this MANY times on westinghouse LCD sets. .
4/11/2011 5:38:57 PM • Westinghouse... • Answered on Apr 11, 2011
Westinghouse LTV-27W2 27 in. HD-Ready LCD Television Logo
95 questions posted
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
westinghouse ltv 27w2 27in hdtv ready
  • Televison & Video
