20 Most Recent
eMachines eME528-2012 Laptop Questions & Answers
How do I enable bluetooth E728
I used to work for Acer (who own emachines) and I am pretty sure that that unit does not have a Bluetooth module, if you did it would start loading drivers & set itself up as soon as the button or key combo was pressed, it was a manufacturers option not standard.
When you press the key or button it will state in green lettering at bottom of screen "NO BLUETOOTH DEVICE".
12/20/2013 11:03:57 PM •
eMachines...
Answered
on Dec 20, 2013
Bluetooth
restore go to control panel and use utility system restore put the last date that you know was working Good.God bless you
7/19/2013 2:56:15 AM •
eMachines...
Answered
on Jul 19, 2013
I want us the camera
check whether the driver of cam is installed or not and also install some cam application like manycam
2/1/2013 12:44:04 PM •
eMachines...
Answered
on Feb 01, 2013
E528 screen black
Sometimes it is no more complex that the contrast is set incorrectly. This would be the first place to look. Should be a key combination on the laptop to adjust it.
Hope this helps. I would appreciate your feed back as I do this for fun not pay.
8/31/2012 7:28:01 PM •
eMachines...
Answered
on Aug 31, 2012
Did not receive a manual
Probably not. There should be some help files on your computer under the "programs" menu.
If you need more, go to the e-Machine site and look there.
7/9/2011 7:11:02 AM •
eMachines...
Answered
on Jul 09, 2011
What is my wpa passphrase or wpa key
if you have forgotten your access key/password, you will need to reset, and then reconfigure your router to create a new password. You can find information on how to do this for your particular brand/model of router both in the router's manual, and on the manufacturer's website.
12/28/2010 4:24:54 AM •
eMachines...
Answered
on Dec 28, 2010
I counted 13 quick beeps at startup on an emachines E520. what dose that mean ? how do i fix it please ?
Thirteen quick beeps at startup on an eMachines E520 usually indicate a problem with the laptop's RAM (Random Access Memory). This could mean that the RAM is not properly seated in its slot, or it could be a sign of a faulty RAM module.
Here are some troubleshooting steps you can try to resolve this issue:
Turn off the laptop and disconnect it from the power source.
Remove the battery from the laptop.
Locate the RAM compartment on the bottom of the laptop.
Check to make sure that the RAM module is seated properly in its slot. You may need to remove and reinsert the RAM module to ensure a proper connection.
Replace the battery and turn on the laptop.
If the problem persists, try removing the RAM module and testing it in a different laptop or using a different RAM module in the eMachines E520 to determine if the problem is with the RAM module itself or with the laptop's RAM slot.
If none of these steps solve the problem, it may be necessary to contact a computer technician for further assistance..
3/22/2023 9:07:20 PM •
eMachines...
Answered
on Mar 22, 2023
How to factory reset a Emachines Etower 633id it boots up but says operating system not found it has Microsoft Windows ME Millennium Edititon (from Windows 2000 Professional)
- Boot the computer to the boot menu: To do this, restart the computer and press the appropriate key when prompted to enter the boot menu. On most eMachines computers, this is the "F12" key.
- Select the CD/DVD drive as the boot device: Use the arrow keys to select the CD/DVD drive and press the "Enter" key to boot from it.
- Insert the Windows ME boot disk: Insert the boot disk into the CD/DVD drive and restart the computer.
- Choose the "Start Computer with CD-ROM support" option: When prompted, choose the "Start Computer with CD-ROM support" option.
- Run the Windows ME setup program: The setup program should start automatically. Follow the on-screen instructions to install Windows ME.
- Format the hard drive: During the setup process, you will be prompted to format the hard drive. Choose the "Full" format option to erase all existing data and perform a complete factory reset.
- Install Windows ME: Continue to follow the on-screen instructions to complete the installation of Windows ME.
After the installation is complete, the computer should be in a factory reset state and you can begin setting it up as a new system.
Please note that resetting your computer to the factory settings will erase all personal data and installed programs, so be sure to back up any important data before proceeding with the reset.
2/13/2023 2:51:11 AM •
eMachines...
Answered
on Feb 13, 2023
My local disk E is missing.
device manager
1 of 10000 model ODD optical disk drives made,
each drive made has LIMITS some only do CD ROMS
BD is blue ray , FIY
if missing or maked with red or yellow errors or shows up as unknown that all means DRIVER IS BAD , wrong or missiong
NO PC Told so can not tell you how to fix that, lacking such a key fact . (but is at your oem makers PC support page under DRIVERS)
6/21/2022 8:52:19 PM •
eMachines...
Answered
on Jun 21, 2022
Hi! I have an emachines laptop E525.I is not going on
moved you out of monitors and into laptops, only forum. emachines
full model not old like this example
E525-901G1Mi
windows 7 loaded day1.
- the switch is bad Lid close switch
- set wrong in power settings.
- or the driver is missing that makes this switch work.
so why not just assign the sleep mode, to auto sleep
then on what does the power button do in settings, set to
do nothing or set button to only sleep . (3 choices here)
or
let auto sleep do the work, set. set to say 5min idle.
the switch is inside it deep and if you rip it out as you go there most noobs break 2 or 3 FFC cable jacks and now it is bricked and $300 mobo wrecked
emachines or junk grade, made by Acer.com owned now
and that maker does NOT have service manuals making service a royal Pain.
best is work around the problem as I just told how.
or ask any shop to fix it.
they do know how.!!!
5/16/2022 1:18:24 PM •
eMachines...
Answered
on May 16, 2022
