20 Most Recent Samsung BD-C6900 Blu-ray 3D Player Questions & Answers
This disk does not fit the specifications
With a Samsung playe you go into your settings and for your BD Live feature you 'PROHIBIT" it and the disc will work fine. Here are the steps.1) Settings2)Network3)BD-LIVE Interernet Connection4)Select PROHIBIT5)EXITit is good to go back ito menu to make sure it saved it.
9/19/2022 12:25:16 AM • Samsung BD-C6900... • Answered on Sep 19, 2022
3answers
I bought a Samsung BD
Here is a solution: http://www.videohelp.com/dvdhacks/samsung-bd-c6900/10895
Please note, however, that even after region code hack, it may remain NTSC only, so if you are planning to play European DVDs recorded with PAL system, it may not work.
8/23/2021 8:28:00 AM • Samsung BD-C6900... • Answered on Aug 23, 2021
Does the bd-c6900 Blu-ray 3d player play4k content
older models does not support 4k content
12/28/2014 6:15:52 AM • Samsung BD-C6900... • Answered on Dec 28, 2014
Samsung bd 6900 stopped playing blue ray or 3d movies
check if the firmware is updated,if those bluray disc are previously working on that machine if thats the case then the unit needs to be repair, the lens of the bluray might be faulty
12/28/2014 5:58:26 AM • Samsung BD-C6900... • Answered on Dec 28, 2014
Bd-c6900 only some programs connect
I have the exact same issue did you ever find a fix?
7/31/2014 4:46:31 AM • Samsung BD-C6900... • Answered on Jul 31, 2014
0answers
2answers
Blu-ray 3D movies doesn't play through a Bose home
leave the Blu-ray connected to the TV. Now run a separate connection from the "audio out" of the Blu-ray to "audio in" at the back of your home theater. That is, you will connect the blu-ray to the theater for sound.
Get a RCA cord (Red and white), connect it to Audio Out, at the back of your blu-ray. Then connect the other end to "Aux in" or "CD in" or "video in", depending on the input at the back of the theater, but it has to be "Audio in" (Red and White/ L&R).
After the connection, select the input on your theater. Take for instance, if you connect the input on "Aux", press "Aux" on the theater, and sound will come out through that channel.
This is what you are going to do, in order to get sound from the theater system. So, the HDMI between the player and the TV will bring display.
I hope the above makes sense to you or hope you understand the above.
In case you don't know what a RCA cord looks like, below is a image that will help you out;
Good luck.
8/11/2013 11:24:58 AM • Samsung BD-C6900... • Answered on Aug 11, 2013
Samsung bd-c6900 xaa dvd player freezes on 3d prometheus movie in same spot at scene 20
Report the error to Samsung support. There is an ongoing problem with the firmware. Make sure you have updated to the most recent firmware version 1025.0 that was released this month. There are still unresolved problems with the new firmware release though. Many movies will fail to load and other will load and play but will skip/freeze during playback. This is related to the anti-piracy features on the Blu-Ray that the player can not properly handle.
3/31/2013 2:50:11 PM • Samsung BD-C6900... • Answered on Mar 31, 2013
My samsung blu ray home theather does not play blu ray dvd''s, first time that i used it, it did played like for 10 min long, but then the image stoped and did not wanted to play any more, i t
Players often when the optical pickup in them is either dirty or beginning to fail will first have problems with blu rays because of technical standards are much more refined for the blu rays.
4/23/2012 11:10:44 PM • Samsung BD-C6900... • Answered on Apr 23, 2012
Bluray BD-6900 turns and is stuck on Load. No menu, nothing on screen, just the word LOAD displayed
HelloIts laser pickup unit should be suspected. Just insert a lens cleaning disc and try to clean it. If it do not help you, the set need service
3/5/2012 6:48:56 PM • Samsung BD-C6900... • Answered on Mar 05, 2012
How to unlock samsung bdc6900
1. Ensure that there is no disk in the tray.
2. Switch the player off and then back on. This is necessary to clean-boot the firmware.
3. After the "No Disk" message appears, do the following.
4. Press the REPEAT button - just above the TV channel selector at the bottom right of the controller.
5. Enter 7 6 8 8 4 on the number pad.
6. After a sec or two, the region code (for whatever region it is currently set to) should appear at the top left corner of the screen.
7. Wait till this number disappears.
11. Enter a "9" to make the player region free. Wait till the number 9 disappears.
12. Power down and power up again.
13. Play a foreign DVD to verify the change.
Please Note your timing , when entering the code is crucial, dont press the buttons too quickly but also dont enter them too slowly, dont pause while entering them either, or you will have to start again. This is very important
if you found this info useful please vote for me
4/11/2011 6:20:31 PM • Samsung BD-C6900... • Answered on Apr 11, 2011
Samsung BD-C6900 Blu-ray 3D Player Logo
29 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
bd c6900 blu ray 3d player play4k
  • Televison & Video
