20 Most Recent Apple iPod mini M9160LL/A MP3 Player Questions & Answers
2answers
Hoe to download music to my ipod
There are lots of methods. You can resort to online music download website, chrome extension, or music download software. Follow below steps, to know the detailed information. Leawo Music Recorder is a super recording software to help you record various kinds of music from multiple sources like online music like YouTube, computer audio, and built-in input audio. The recorded music files will be saved into an output format of MP3 or WAV. 1. Run Music Recorder on your computer and enter the recording interface. Audio source should set firstly before music recording. In order to record the music from YouTube, we should choose the option "Record Computer Audio". 2. Click the red button "Start" to make Leawo Music Recorder begin to work. Then play the music on YouTube. You should note that the music recorder should work prior to playing YouTube music. If you want to decide the start and duration time of the recorded music, just click the icon button "Task Scheduler" then you can finish this customized setting as per your requirement. After the music has been recorded from YouTube, you can use Leawo iTransfer to move the recorded music from computer to your iPod Leawo iTransfer is a professional transfer program for transferring files between iOS devices, iTunes and computer. Various kinds of files are supported by this software such as music, apps and photos, etc. 1. Run Leawo iTranfer after you have downloaded the music on your computer. Connect your iPod with your computer via USB cable. The library of your iPod will be detected automatically and shown in the left sidebar of the window. 2. Import files to the software from computer in the following four-way: I. Drag and drop the music files into iTransfer directly. II. Click the button "Add" on the upper part which is beside the left sidebar. III. Click the button File > Add > Add File/Add Folder on the top right corner of the window. IV. Right click on the library and select Add File or Add Folder. 3. A pop-up dialog will be shown once you finish adding files and press the "Transfer" button. The name and the quantity of the transferred files will be demonstrated to let you know the transferring percentage. Remember not to disconnect your Apple device to your computer until the transferring is completed. music-recorder-recording-t-ptaos1411zhprwnu0jdtasew-5-0_3.jpg For more details, check: How to Download Music from Your Computer to iPod
4/19/2019 6:20:15 AM • Apple iPod mini... • Answered on Apr 19, 2019
My ipod will not sync the sync button on my itunes device is greyed out?
Make sure you click on your device icon before attempting to synch, it could be that easy.
2/20/2015 5:39:56 AM • Apple iPod mini... • Answered on Feb 20, 2015
How delete the memory
For instructions on resetting your iPod to factory settings, click here: Restoring iPod to factory settings
2/2/2015 9:36:32 PM • Apple iPod mini... • Answered on Feb 02, 2015
How can i unlock if i forget the password
For unlock instructions, click on the Apple help site: Forgot passcode for your iPhone iPad or iPod touch or your device is...
2/2/2015 9:10:31 PM • Apple iPod mini... • Answered on Feb 02, 2015
My apple mini i.pad will not connect me to my yahoo account. It tells me that "my time has run out.
Make sure that you have a strong internet connection with your iPad, and that you are entering your login information for your yahoo account correctly.
9/18/2014 1:42:30 AM • Apple iPod mini... • Answered on Sep 18, 2014
Language on my ipod is chineese - need english
restore it through itunes
4/24/2014 6:18:59 AM • Apple iPod mini... • Answered on Apr 24, 2014
0answers
Ipod hang
Be the first to answer 4/15/2014 6:43:25 AM • Apple iPod mini... • Posted on Apr 15, 2014Be the first to answer
What software should i downlaod and how to use it'
ios 4
1/1/2014 10:43:10 PM • Apple iPod mini... • Answered on Jan 01, 2014
Remove contact in skype from my mini ipod
I take it that it is skype on an ipad mini, the first thing you do is go to people click on the contact once you are in the relevant person click on the gear wheel in the top right hand corner and then you can remove the person from contacts. Hope this helps.
4/5/2013 7:05:36 PM • Apple iPod mini... • Answered on Apr 05, 2013
APPLE IPOD 4GB FREE SOFTWare
can you please be specific...?
10/18/2012 7:13:19 PM • Apple iPod mini... • Answered on Oct 18, 2012
Ipod reset code
Hi ericconley90If you have forgotten the code, you can unlock the IPod by doing the following:Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.If you want to change the primary computer that your IPod is associated with, do this:1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.2. Connect your iPod to the computer that you want to be the primary computer.3. Open iTunes and synchronize.If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data.Please take time to rate me Bud
10/18/2012 2:17:14 PM • Apple iPod mini... • Answered on Oct 18, 2012
Ipod is disabled
Hi Rita Parker...If you have forgotten the code, you can unlock the IPod by doing the following:Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.If you want to change the primary computer that your IPod is associated with, do this:1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.2. Connect your iPod to the computer that you want to be the primary computer.3. Open iTunes and synchronize.If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data.Please take time to rate me Bud
9/27/2012 8:09:42 PM • Apple iPod mini... • Answered on Sep 27, 2012
How do i setup a apple id
It should ask you to set one up right when you turn your iPod touch on for the first time. Follow the prompts and it will guide you through the steps.
8/25/2012 12:17:22 AM • Apple iPod mini... • Answered on Aug 25, 2012
Ipod nano not charging
you should probably contact whoever u got it from,or go to best buy theyll switch it out
7/8/2012 12:20:52 AM • Apple iPod mini... • Answered on Jul 08, 2012
How to get vidio
you can download video from youtube.and a youtube downloader can help you deal with that.i have used this one for a long time to help me download videos from youtube.This youtube downloader can not only download the videos you like from youtube,but also can convert the videos to the right format you need at the same time.here is the link for the Free youtube downloader.
3/23/2012 3:32:36 AM • Apple iPod mini... • Answered on Mar 23, 2012
Operate a ipod
Go to http://www.apple.com/uk/support/ipodmini/ you will get all the information there. Hope this helps.
1/22/2012 8:13:56 PM • Apple iPod mini... • Answered on Jan 22, 2012
Apple iPod mini M9160LL/A MP3 Player Logo
Popular Tags
117 questions posted
Popular Products
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
iPod Apple
  • iPod Apple
Most Popular Question
frozen pod 8gb
  • Audio Players & Recorders
