20 Most Recent
AT&T MC-60 Microcassette Tape Micro Cassette Questions & Answers
Cassette replacement
Well....first of all....you shouldn't need to erase cassettes....this is done automatically when they are recorded over when reusing them. As far as finding replacement cassettes you should find them online with a search. You could try Ebay, or just a general search should turn up some suppliers, or used ones.
MC-60 tape says, "end of
Wow, microcassettes! (Sorry, I thought they were so cutting edge when they were.......cutting edge!)
Anyway, forgive the humour - you've most likely got a tape jam in the cassette itself but if it does this with other cassettes then you've got a dead rewind function your message indicates that you've got a later model recorder with a status display.
What does Fast Forward do?
I know it's annoying but the cheapest option may be to turn the cassette over and use FF if it works OK.
Have you checked out digital pocket recorders?
For the same money, or less, than yours likely cost new, they free you from cassettes, tape winding time, poor quality - all those analogue hassles.
The memory (time) capacity even the most bog-standard (as we say in the UK!) ones have is mind blowing.
Problem with oelmaier pac2 inverter
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjckMaPzKODAxUVj4kEHR5mBFMQFnoECBQQAQ&url=https%3A%2F%2Fforums.whirlpool.net.au%2Farchive%2F1447917&usg=AOvVaw1FGjdFQoufkwdXZJgXWdGz&opi=89978449
Inverter problems
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj_qqPyyKODAxWLHjQIHZRbAW8QwqsBegQIDhAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DZ6e4aMeAfGQ&usg=AOvVaw1gC1aMLjnqHmsV7v7EZaQm&opi=89978449
Rca 16mm projector 201 pg no sound exsiter lam of
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiX9MCToeeCAxWXv4kEHeF-DZcQFnoECCEQAQ&url=http%3A%2F%2Fwww.film-tech.com%2Fubb%2Ff1%2Ft000301.html&usg=AOvVaw3MnkgK0sKTHX7t5pvECIT5&opi=89978449
Lanzar sd82 input output plug layout
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi8krnznueCAxWxrokEHT0iBfoQFnoECA4QAQ&url=https%3A%2F%2Fwww.manualslib.com%2Fmanual%2F577337%2FLanzar-Sd82.html&usg=AOvVaw1NvtQPbnDX49X9-I6oRe-J&opi=89978449
