20 Most Recent
Nvidia Riva TNT2 16 MB Graphic Card Questions & Answers
DFI NB78-BC, chipset i845PE does not work with TNT2 Vanta VL 16MB
I hate to be the bearer of bad news but the DFI NB78-BC does not support the TNT2 Vanta VL 16mb. so what you need to do is take your computer into a computer store have them look at it and they can get you the correct video card that is compatible for your computer!
Screen dies when booting up
TRY PLUGGING IN EXTERNAL MONITOR, THIS IS IF YOU HAVE A LABTOP AND I THINK NOT.
HOW ABOUT REMOVING THE OLD DRIVE AND PUTING IT ON THE NEW COMPUTER AS 2ND DRIVER OR SLAVE DRIVE, SOME COMPUTER CABLES OFFER SELLECT CABLE THE C DRIVE WOULD BE 0 AND 2ND DRIVE WOULD BE 1, IF YOU DONT HAVE SELECT CABLE THAN EACH DRIVE HAS TO BE SET UP YOU WILL HAVE TO GO TO THE MFG WEB SITE LOOK UP JUMPER SETTINGS, THE FIRST DRIVE WILL BE THE MASTER AND THE SECOND ONE WILL BE THE SLAVE, NOW IF YOUR CD ROM IS ON WITH THE HD THAN YOU WILL HAVE TO HAVE 2ND CABLE FOR THE CDROM TOPUT ON THE 2ND SET OF PINS MARKED 2ND HD OPTION AND YOU HARD DRIVERS MASTER AND SLAVE GO ON
BANK 0 IF IT SAYS 0, IF IT SAY1 THAN PUT IT ON 1.
REBOOT AND THE COMPUTER WILL START AND PUT YOU INTO THE CMOS AND YOU WILL ADD THE HARD DRIVE BY GOING TO 2ND HD PUTTING CYCL, HDS, SECT, YES LBA
2ND CABLE YOU SELECT CD OR DVD
F10 AND YES
REBOOT
EVERYTHING SHOULD WORK FINE.
IF YOU DONT FILL CONFERTIBLE DOING THIS TYPE OF INSTALLATION THAN HAVE YOUR COMPUTER PROGRAMER FRIEND DO IT FOR YOU OR COMPUTER TECHN WILL WORK TOO.
ROD
Gt 630 nvidia, error code 43
Update your video card driver at NVidia.com. More current drivers eliminate the conflict caused by having 16GB RAM.
Need Nvidia pcg 7v1m driver Graphics win.7
go google and type in--- nvidia drivers -- download the driver for your graphics board and win 7
or if you have a graphics board already install click on the board and change compatibility to win 7 in the properties tab
you will also find an update drivers in the sam properties section
Nvidia gfx card problem
It seems that the problem lays on your Ram,not the graphic card.And since the driver of graphics card is capturing some of your ram memory you are experiencing this error.
GEFORCE FX 5500 NVIDIA PROBLEM
Official sources of Nvidia don't support windows xp anymore.Try to download the correct windows xp driver from an unofficial source.If you are not able to find one,you have to upgrade your O.S to a newest version.
