20 Most Recent Korg PA50SD Pro 61 Key Keyboard Bundle Questions & Answers
Korg pa 50 sd no minus 8v from power supply ic
Have the same issue
11/11/2023 12:16:47 PM • Korg PA50SD Pro... • Answered on Nov 11, 2023
How do I respond to 'os not found insert card with the os then restart the instrument' message?
For the best info contact Korg customer support. Here is the link- http://www.korg.com/us/support/contact
4/14/2018 7:03:51 PM • Korg PA50SD Pro... • Answered on Apr 14, 2018
Its frozen and cannot load
It is power supply regulator problem. In the regulator circuit, DC 12volt from adapter is separated into +8V, -8V, +5VA, +5VD' Some causes when the unit hang / frozen is one of the existing supply voltage is drop. In general, +5V. Also check the adapter voltage, if still normal and the current is sufficient. Adapter must have DC12volt and current of at least 3 amperes. It may happen, when the adapter is measured without load, it's read normal,12v. But when loaded to turn on the keyboard, many voltage decreases (lets say,between 8-10v). This indicates that the adapter is not good.
9/1/2015 7:18:23 PM • Korg PA50SD Pro... • Answered on Sep 01, 2015
Some keys of my pa 50 sd, wont work right away after keyboard is turned on. it takes about one hour to keys start playin, only some of them, what should i do.
Take it back to where you bought it, and get it serviced, to clean the dirt-filled contacts.
6/13/2014 5:47:03 AM • Korg PA50SD Pro... • Answered on Jun 13, 2014
2answers
Hi i got the korg
NOT a fuse... thaat person knows nothing. There is something wrong for sure. Check if one of the buttons or keys MIGHT be stuck down (depressed). Sometimes the units check that all the control buttons are up and they don't really tell you why they fail to start. Beyond this a repair shop is in order.
12/17/2011 8:50:12 PM • Korg PA50SD Pro... • Answered on Dec 17, 2011
I need a fuse for a Korg N364 keyboard.
No one knows the fuse type, but the details should be on the fuse itself. Then you can't get them from an electronics store or Amazon. The Service Manual is in the link. https://www.google.com/search?q=Korg+n364+keyboard+replacement+fuse ..
4/12/2024 4:58:31 AM • Korg Music • Answered on Apr 12, 2024
Korg D3200 asks for start up disc. Will not boot.
If you contact Korg, they can send you a dowloadable link to burn the software to a disc.
11/21/2023 9:36:55 PM • Korg Music • Answered on Nov 21, 2023
Hello. I am in possession of Ix300 Korg music workstation that is not able to boot up properly. Any chance of repairing?
up to you if you ant to spend the money to have it diagnosed and repaired
11/3/2023 2:31:49 AM • Korg Music • Answered on Nov 03, 2023
Loading system failed Korg m50
9/6/2023 8:00:59 AM • Korg Music • Answered on Sep 06, 2023
2answers
Korg X50. When switched on, why does it indicate: 'Waiting for the data from USB'?
Sounds like loss of memory\programming.Go to Korg website for download.
12/30/2022 3:04:37 AM • Korg Music • Answered on Dec 30, 2022
Korg PA50SD Pro 61 Key Keyboard Bundle Logo
Popular Tags
14 questions posted
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
korg pa 50 sd no minus 8v from power
  • Music
