20 Most Recent
Compaq iPAQ PM-1 Personal CD Player Questions & Answers
Cannot hear sound
they might be muted or have faulty connections/leads
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
No sound
settings there
also
untick it
problem
adjust volume
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this
helps
My compaq 511 laptop's speaker
settings there
also
untick it
icon in taskbar for any further volume adjustment you will need to right click
on the volume icon depending on your operating system select adjust volume
problem
connection is good
helps
Computer is not playing sound.
you might need to install sound drivers
Right click to reinstall drivers hope this helps you
My hard drive died, and
You will need to go to
www.realtek.com and you can download your sound drivers after the installation is complete you will be able to hear the sounds.
any further help please use the comment box below and will get right to you.
Kronoguy
