20 Most Recent Lenovo b560 Notebook Questions & Answers
3answers
Blank screen
cpu light's is on or off? if it's off you check the connection and then if it's not solve and you see the screen in the sun light if it's have a any damage you see the liquid in your screen....
8/26/2017 9:53:47 AM • Lenovo b560... • Answered on Aug 26, 2017
Usb not recognition any usb device into bios and booting
Try a different flash drive if you're trying to load an OS installation.
5/8/2015 9:21:11 AM • Lenovo b560... • Answered on May 08, 2015
How do I disable the touchpad on my Lenovo B560 laptop
You can go to Control Panel and use the Mouse Icon. There you will find the option to disable the touchpad.
2/28/2015 7:57:41 PM • Lenovo b560... • Answered on Feb 28, 2015
Mine is b560, i drop it but its not that i high together with its case. i see that the back portion of the screen edges was opened, how can i fix it?
Please post the photo of that area. Probably it just need to be gently pressed.
3/10/2014 8:19:21 PM • Lenovo b560... • Answered on Mar 10, 2014
I dropped my on the floor. it was off at the time. Now I have a blank screen.
The display board may be broken it has three replaceable units 1. Screen (if damage / broken into pieces) 2. Display Connector (Which can damage when you drop) 3 The processor can be dislocated / even damaged severly the best decision is to replace those part through service center
1/27/2014 1:30:50 AM • Lenovo b560... • Answered on Jan 27, 2014
0answers
Unknown device
Be the first to answer 12/20/2013 9:21:59 PM • Lenovo b560... • Posted on Dec 20, 2013Be the first to answer
0answers
0answers
Lenovo overheat
Be the first to answer 11/10/2013 4:27:45 AM • Lenovo b560... • Posted on Nov 10, 2013Be the first to answer
Touchpad, I want to disable the touchpad/mouse,
check on the F1 to F12 buttons one of them come with the laptop Mouse icon, in different color most times, Use FN button (close to CTRL button) + the mouse button, it may disable it..send me the brand and model of the laptop, I might help you better
9/7/2013 9:34:51 PM • Lenovo b560... • Answered on Sep 07, 2013
Os is working but i could see only black screen after i switch on my laptop?
First i will suggest you to restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.If you able to start in safe mode then update your graphic drivers from the manufacturer site Let me know if it helps you.Use system utility tool like RegInOut to remove unwanted files and fix registry and windows errors which causing black screen
7/5/2013 6:12:48 AM • Lenovo b560... • Answered on Jul 05, 2013
Lenovo troubleshooting
Update your drivers in the computer. Scan your computer with RadarSync to know which drivers are outdated then update them.If you can still remember the time when the computer was still working just fine, then do a system restore to that time. I hope this helps!David
5/2/2013 2:42:47 PM • Lenovo b560... • Answered on May 02, 2013
2answers
Keyboard won't work
When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement. Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
1/15/2013 9:25:31 PM • Lenovo b560... • Answered on Jan 15, 2013
Lenovo b560 win7 64 bit can't see USB storage device
Which OS you are using? If it is XP then you may have to download the driver and then install it. Also check firewall settings because it can block certain devices. Even in xp thumb drive should work perfectly. Parts For Mercedes Benz
12/12/2012 1:49:21 PM • Lenovo b560... • Answered on Dec 12, 2012
I have a 'pin' stuck to my curser when I close a window!!! Help!!!
Try this: http://www.filehippo.com/download_avg_antivirus_32/download/5dbfa7611ef774e88fba9feb2d3172e4/
10/19/2012 2:09:09 AM • Lenovo b560... • Answered on Oct 19, 2012
0answers
When i start up my computer i keeps asking for an HDD Password
Yikes!!! I'm not calling you a thief, but 99% of the time when you encounter a laptop that has a lock on the hard drive and the person in possession of the laptop does not know the password, the laptop is stolen. The original owner put the lock on to keep thieves from getting to sensitive data. It could have been put on remotely by the original owner once they realized the laptop was missing.You're up the creek without a paddle.
6/8/2012 3:10:32 PM • Lenovo b560... • Answered on Jun 08, 2012
Lenovo B560 screen goes black after boot
Reinstall your operating system.
5/9/2012 9:03:32 AM • Lenovo b560... • Answered on May 09, 2012
Lenovo b560 Notebook Logo
41 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lenovo Computers & Internet
Most Popular Question
keyboard won 39 t work
  • Computers & Internet
