20 Most Recent Creative Labs MuVo Micro N200 MP3 Player Questions & Answers
Maybe it's time for you to upgrade to a new mp3 player. I guess the regular one you have right now is probably old. If not old, try to see if you can get the manufacturer that owns the product to see if they can fix the issue. If they are not able to assist, then maybe you can troubleshoot it.
Creative Labs... | Answered on May 13, 2017
hi! all,
when i connect my muvo n200 256MB, it show h: is not accesible. The request could not be performed because of an I/O device. Please help what can be done. please reply
sibinkumar
Mumbai
Creative Labs... | Answered on Mar 22, 2010
Reformat the mp3 player and reload firmware.
Creative Labs... | Answered on Sep 24, 2009
This firmware upgrade only works with Creative MuVo Micro N200 players. Do not install this upgrade to other players.
You will lose all content in your player when you install the firmware. Back up any audio or data files in your player to your computer before upgrading the firmware.
Before installing the firmware, please complete the following procedures:
  1. Download the latest device driver if you have not installed any drivers for your player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe.
  2. Connect your player to your PC.
  3. Close all active applications (for example, Internet Explorer, Windows Explorer, or Windows Media Player etc), as well as background applications such as Norton anti-virus applications.
  4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen.
To install the firmware for your player, follow the procedures below:
  1. Download the firmware update, MuVoN200_PCFW_LF_1_20_04.exe to your hard drive.
  2. Connect your player to your PC if it is not already connected.
  3. Double click the firmware upgrade file.
  4. When prompted to set your player in Recovery mode, disconnect your player from your PC.
  5. Remove the battery from the player, press and hold the Play button while connecting the player to the USB port.
  6. Continue to hold the Play button for about 10 seconds after your player is connected to the USB port.
  7. When the Find New Hardware dialog box appears on your PC screen, release the Play button.
  8. If this is the first time a player is installed as Player Recovery Device, Windows will find a Player Recovery Device (or USB Device), and prompt you for drivers. Click on No , and select Do not search. I will choose the driver to install. Windows will install the necessary drivers automatically.
  9. Double click on the downloaded firmware again (MuVoN200_PCFW_LF_1_20_04.exe) to update the player's firmware.
  10. During the firmware update process, make sure to check the box next to Format Data Area under Download options.
Creative Labs... | Answered on Dec 26, 2008
It can also be caused by transferring DRM (Digital Rights Management) encoded media files via the drag and drop method. It is recommended that you use the drag and drop method to transfer audio files that are not encoded with DRM. If in doubt, use either Creative MediaSource Organizer or Windows Media Player to transfer your files.
To resolve this difficulty, we recommend that you format the player and transfer the content again. You can also download and install the latest firmware, and select the Format Data Area option during firmware update.
To format a MuVo player, connect it to a USB port on your PC. Open the Windows Explorer, and locate the Removable Drive listing and right click on it. Select Format, and choose FAT instead of FAT32 or NTFS. After the formatting is complete, make sure that you stop your player before disconnecting it from your PC (see above)
To update or reload the firmware for a MuVo player, select the model of your player from below.
Creative Labs... | Answered on Apr 10, 2008
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
Creative Labs... | Answered on Jan 21, 2008
you have a bad displayor the connector to the display is comming off.
do you have the latest firmware and are you using new batties?
http://us.creative.com/support/downloads/welcome.asp?action=next
Creative Labs... | Answered on Dec 06, 2007
Did you format it properly?
Usually MP3 Players are to be formatted with the FAT32 File System. This can be easily done on Windows.
Simply connect the Mp3 Player to your computer via the USB. Then Windows should be able to detect it just fine. Go to My Computer and right clock on the new device (that is the MP3 Player) and select "Format".
Format as FAT32 and try again.
PS: You may want to backup all data (if that is possible) before you attempt this Format thing.
Creative Labs... | Answered on Oct 17, 2007
look for a tiny pinhole and insert a pin while powered up to reset the device
Creative Labs... | Answered on May 27, 2007
If you've tryed to leave out the batterys more then a day or so?? if not try it BUT if this dosent help it may be time to get a new mp3 . Sorry but there are no real user serviceable parts inside of these puppies. Good Luck
Creative Labs... | Answered on May 02, 2006
Try searching again using Google, using BT 9843, but when you look down the results ignore the two letters and see if you can find an IC which is the same numbers, even if it has different letters on the front. Those letters could be just the makers letters, with the device made by different makers.
Creative Labs... | Answered on Jun 15, 2018
If the brightness is all the way down, simply turn it up.
If not this indicates an issue with the device and you should take it to your local tech repair shop
Creative Labs... | Answered on Oct 30, 2017
Creative Labs MuVo Micro N200 MP3 Player Logo
25 questions posted
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Creative Labs Audio Players & Recorders
Most Popular Question
file system error
  • Audio Players & Recorders
