20 Most Recent
D-Link dlinkgo Wireless N 300 Router (790069342394) Questions & Answers
Http://www.192.168.0.1
Using your browser, the IP address should connect to the router but n=do not use the www just use
http://192.168.0.1 to connect.
then the router us ADMIN for login and leave password blank (unless you changed it) to get to the router set-up.
How to configure router
read user manual
http://www.dlink.com/-/media/Consumer_Products/GO/GO%20RTW%20N300/Manual/GO_RTW_N300_A1_Manual_v1_00.pdf
Can not install software???
I find the built in windows software normally works fine, But it was probably disabled when the software was installed.You can either plug into your router with an Ethernet cable and download the new software or enable the windows wireless.To enable the windows wireless configuration right click the WIFI connection and go to properties ,wireless networking tab and then check the top box saying use windows to configure my wireless network settings.
Wireless set up
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router. Connect a LAN cable from the Linksys to the LAN port on your computer. Open a browser and enter the Linksys configuration URL http://192.168.1.1 The default login = admin The default PW = admin You can protect your router by changing the default admin PW (write it down and put it in a safe place) Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access. Now apply these settings to the wireless card in your laptop/computer. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
To a password on my dlink wifi
router
If you have forgotten your password you can reset by hitting the reset switch on your router. This is a pinhole on the back of the router near the power cord. Use a pen or pencil to push the button at the bottom of the pinhole to reset the router.
How to conect a router
Plug a computer into the LAN port and in an internet browser, go to 192.168.1.1 to set up wireless. WPA and WPA2 security, make a key for wireless security and then insert that key for the wireless devices such as a laptop when you try to connect to your SSID.
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
