20 Most Recent HEWLETT-PACKARD HP 4525s ProBook Questions & Answers
Users manual for ProBook 4525s
http://www.manualslib.com/manual/437297/Hp-Probook-4525s-Notebook-Pc.html#manual
3/16/2015 9:40:00 PM • HEWLETT-PACKARD... • Answered on Mar 16, 2015
Enable usb boot
It's done in BIOS F10 on HP/Compaq
2/14/2015 3:49:49 AM • HEWLETT-PACKARD... • Answered on Feb 14, 2015
FIND printer CMOS BATTERY in HP J6413 printer
Not sure they have a CMOS battery but you can perform a factory reset Try this http://www.ehow.com/how_5757518_reset-memory-hp-officejet.html
4/13/2014 10:39:02 AM • HEWLETT-PACKARD... • Answered on Apr 13, 2014
How to turn on webcam
The quickest way to find your webcam is to click start, type in "web" it should be on the top of the search, then just click to open it. If it is disabled go to your control panel, click hardware, then Divice Manager. It will bring up your system Devices. Click on Imaging Devices. It will bring up your webcam, click it, then then click "Driver." Click to enable it. Some laptops may have a "hotkey" to turn it on, the key will usually have a camera icon, it is an "f" key. Mine does not, so I cannot tell you which key. Does this help you? Ponder/Meditate/Pray for Peace. Mary Oliveau { hugs }
1/24/2014 12:40:19 AM • HEWLETT-PACKARD... • Answered on Jan 24, 2014
Computer continually reseting
Hello, I will need to know what operating system you are using and does all the programs reset itself?
1/23/2014 3:56:31 AM • HEWLETT-PACKARD... • Answered on Jan 23, 2014
Optical Drive Malfunction
test with software diagnostic coming with HP, and fix it.Maybe the drive is corrupt, and need to uninstall and install update drive.God bless you
6/19/2013 12:54:33 PM • HEWLETT-PACKARD... • Answered on Jun 19, 2013
I cant restore my HP Probook 4525 to the factory settings. I have no discs and I need to restore to original
Manufacturers often provide a pre-installed factory restore utility. Have a look in your all programs menu and see if you have anything like that installed as this would be the most straight forward option for you.
1/9/2013 10:38:46 AM • HEWLETT-PACKARD... • Answered on Jan 09, 2013
Cmos jumper
To set the CMOS/BIOS back to the factory default you can just remove the BIOS battery for 20 mins oe if you cannot wait then short out the battery holder contacts with a paper clip. Then replace the BIOS battery, go into the BIOS setting and set the Date & Time etc.
9/18/2012 9:39:53 AM • HEWLETT-PACKARD... • Answered on Sep 18, 2012
0answers
2answers
I have a HP Probook laptop and my mouse (touch
Based on the User Guide :
Turning the TouchPad on and off
The TouchPad is turned on at the factory. When the TouchPad zone is active, the light is off.
To turn the TouchPad on and off, quickly double-tap the TouchPad off indicator.
the indicator is on the top left side of TouchPad zone.
Good Luck
12/5/2011 8:57:34 AM • HEWLETT-PACKARD... • Answered on Dec 05, 2011
2answers
I need to turn off
you do not need to install any special software.
Here is what you have to do to turn off the mouse pad of your hp probook 4525s;
Turn on your hp probook 4525s, wait till it boots completely.
Click start,
Scroll to Control Panel select Control Panel.
Under control panel, (you will find a Mouse icon), click Mouse and a dialogue box will pop out.
On the dialogue box, click "Device settings".
Under device settings, you will find "Synaptics Touchpad..."
Highlight the "Synaptics Touchpad..." by clicking on it once, then click disable.
By now the mouse pad should be disabled. Apply the changes for it to take affect.
To enable follow the same procedure and click enable using an external USB mouse.
Yours sincerely.
Elect_Comp.
5/24/2011 8:39:48 PM • HEWLETT-PACKARD... • Answered on May 24, 2011
Somehow I locked the mousepad on my HP ProBook
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart or During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
dont forget to vote hope this helps
2/4/2011 1:49:19 AM • HEWLETT-PACKARD... • Answered on Feb 04, 2011
2answers
When I try to download into quicken the documents page comes up. How do I correct this situation?
If your bank statement is not in the Quicken format, you cannot do that. Best see if it will download into MS Excel. If not, get in touch with the Bank
10/19/2022 4:47:44 AM • HEWLETT-PACKARD... • Answered on Oct 19, 2022
3answers
Back Slash on HP keyboard ProBook
Try now~ Then you can reset your keyboard if you like
5/4/2022 2:32:08 PM • HEWLETT-PACKARD... • Answered on May 04, 2022
HP G72-253NR Laptop - Using an External Keyboard
I think you have a broken USB keyboard or USB port. Simply plugging in the keyboard should be enough to make it work. First try the keyboard in a different USB port. Test the caps lock to see if the LED goes on and off. Also try a different keyboard and also test it in a different computer.
1/31/2019 6:37:16 PM • HEWLETT-PACKARD... • Answered on Jan 31, 2019
Pano pag ang laptop sa HP ay hindi na mag on pero meron syang power?
please use English, ok?
10/30/2018 1:04:04 PM • HEWLETT-PACKARD... • Answered on Oct 30, 2018
HEWLETT-PACKARD HP 4525s ProBook Logo
23 questions posted
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HEWLETT-PACKARD Computers & Internet
Most Popular Question
need turn off
  • Computers & Internet
