20 Most Recent
Dell Pocket DJ MP3 Player Questions & Answers
Dell Pocket DJ does not charge using USB Cord
If you find none of this has worked you need to try some other decvie
in the same usb port. If it is plugged in and operates correctly, you
have narrowed it down to the dj unit. Since the chord has tested good,
we should go to the unit itself. Four tiny screws located on the
outside of the case need to be removed in order to open it. Carefully
remove the hard drive, then the battery.
Now with the cable hooked up to the usb port you will use a meter to
check some voltages. Perhaps you have a friend who can help. The
batteries should read 3.6 VDC. Measured like that its not a true
indication of the state of the batteries, but tell us that the charging
circuit is probably working okay.
Put it back together carefully, making sure every connection is
properly seated and there is no damage. Try it again, making sure you
hold down the button for 3-4 seconds. If you have done all of this, the
problem is electronic and at a component level. Suggest you take it or
send it to the repair shop dell has.
Ted
Dell Dj 5 will not hold a charge
FYI, replacing the battery did not solve the problem of the battery refusing to charge. Instead, I've spent $30 at batteryship.com and since I've opened the battery I can't return it. There must be a software or hardware failure that's preventing the unit from charging the battery.
Battery will not fully charge
the battery is kaput. you can send it to apple and they can install another li-ion battery, for a fee of course....there may be some local stores that can do it as well....go to an apple store, or their website for more info.
Dell.com
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player using the USB cable.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
My Dell Pocket DJ Sofware in not compatible with
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
How do you remove the
Hi, To get access to the battery, you need to use a sharp knife (construction type). Cut the interface between the plastic bottom at the outside casing interface and remove the plastic in one piece. It is sort of glued to the bottom, but it comes off easy once the perimeter is free. Under the plastic cover, there are 4 philips head screws to remove a small metal covering plate. Once the plate is removed, you can see the connector for the battery. Remove the connector and then gently pull the battery out. There is nothing holding it in place except the friction of the other components inside. Mine came out easily.
