20 Most Recent
Dell W1900 19 in. HD-Ready LCD Television Questions & Answers
Problem with remote for Matrix MX 6160T
omg man i cant believe you have the same problem. I honestly dropped my remote half a foot and it just stopped working! i even changed the batteries and it still doesnt work. the shock from the drop is clearly not that bad to break it?.
My main menu button is locked and don't know how?!
if its a w1900 this is a known setting. Press the menu button on the right hand side of the TV (second button UP, just above power/standby. Now, WHILE THE MENU LOCK MESSAGE IS BEING DISPLAYED, press CH ^ and VOL - AT THE SAME TIME. Menu unlocked message should be displayed.
And you're done.
Might take a couple of tries - this tv/monitor is a bit fiddly...
Help me turn my tv on
Dell are a bunch of rip off artists.
Dell tv/monitors turn off if there is no input coming from the selected input. In this case DVI, try powering on the TV and using the menu buttons along with the channel Up/down buttons on the tv to select a different input.
Hopefully this works for you.
I have the same problem also. I am assuming that the power supply is bad. I have looked everywhere and can not find a replacement or the pinout on the supply. If anyone can find a service manual or a replacement board, please let us know.
Dell 32 LCD Flat Screen multiple problems
I have checked all the connections and replaced all the cables with the highest quality I could buy. I think the problem is in the TV tuner itself. I live in a MDU so I am stuck with a rooftop satellite/master antenna.
TV forgets channels when unplugged
Has it always forgotten the channels when you unplug it or is this just a recent development? I know that on my old standard tube television or VCRs, the channel memory is always reset if they are unplugged - the same being true if the power goes out.
Problem with changing channel and volume
your TV is having problem in the power supply area or th secondary power supply where the micro processor is situated.take it to a qualified techn to be repaired.
My Hanspree SC24LMUB has been working as a monitor for my my Dell spx 13 for years, but upon returning from a trip, it now will not connect.
I'm sorry to hear that you're having issues with your Hanspree SC24LMUB monitor. There could be several reasons why it's not connecting to your Dell laptop. Here are a few things you can try to troubleshoot the issue:
- Make sure that the HDMI cable is securely connected to both the monitor and the laptop.
- Check that the HDMI port on the laptop and the monitor are not damaged.
- Try a different HDMI cable to see if the issue is with the cable itself.
- Check the display settings on your laptop to make sure the laptop is set to extend the display to the external monitor.
- Restart your laptop and monitor to see if that resolves the issue.
If these steps don't help, it's possible that there could be an issue with the monitor or the laptop itself. In that case, you may need to contact the manufacturer for further assistance.
