20 Most Recent
Fujitsu P55XHA40US 55 in. Plasma Television Questions & Answers
My fujitsu plasmavision has no volume
check to see if the Mute is on..you may need to call in a technician , in the box itself is a small amp that powers the speakers. This seems to have gone bad in yours and needs replacing. simply look at the speakers and you will see it connected to a small circuit board , that's the amp circuit.
12/30/2012 1:22:18 AM •
Fujitsu...
Answered
on Dec 30, 2012
What is a pdp unit
A PDP is a Plasma Display Panel---the entire front screen unit--on a typical 55 inch Plasma it retails for over 1,000 exchange.
3/29/2012 1:30:50 PM •
Fujitsu...
Answered
on Mar 29, 2012
I have a Fujitsu P55XHA30
They are handled by different chips situated on the mainboard. If the analogue ones are functioning correctly then the chip corresponding to the digital ones has failed.
Unfortunately it cannot be replaced by its own, the entire mainboard would have to go so it will be an extremely expensive repair - the board are very hard to obtain and only for a very high price.
In my opinion you should leave the tv as is, use it with the analogue connectors, and save money for a new one - it will be cheaper in the end that fixing this old one.
9/1/2011 10:41:44 PM •
Fujitsu...
Answered
on Sep 01, 2011
When I am watching the
Kindly provide few more details :-
1. Are you using a cable box?
2. Do you see the picture freezing problem when playing DVD player or game console such as X box?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1/12/2011 4:29:31 PM •
Fujitsu...
Answered
on Jan 12, 2011
Fujitsu 42
Hi Mark,
You have a faulty fan or fans which is causing the screen to switch off as a precaution. A repair can be carried by fujitsu.
Regards
5/25/2010 3:30:07 PM •
Fujitsu...
Answered
on May 25, 2010
Fujitsu plasma tv is on but no picture
Check all inputs. Are they all dead. Try other signal source. Does antenna input work when connected to known good source?Vide input label being displayed indicates most of the tv is working. You need to determine if you have lost signal in the video input.
11/9/2009 1:49:40 AM •
Fujitsu...
Answered
on Nov 09, 2009
Line on screen
It sounds like the actual LCD is damaged, i've seen some cases where it was a damaged cable going to the LCD screen but if the cable looks ok then it is probably the lcd screen.
9/20/2009 3:34:11 AM •
Fujitsu...
Answered
on Sep 20, 2009
