20 Most Recent
Gateway DMP300 (256 MB) MP3 Player Questions & Answers
Cant find the reset button on my MP3 player
Hello, and thanks for using FixYa! The reset is actually format. Go into the menu and find format. Accept the format device and it will reset everything. If this was helpful, please take a moment and rate the solution! Thanks, and Good Luck!
Speaker replacement
If the enclosure has a front GRILL that lifts off or can be pried off without difficulty, you may be able to enter from there.
In most cases the manufacturer seals these devices and you cannot open them. The cost to replace could be greater that purchasing a new sub-woofer. Remember Speakers must be MATCHED properly, and unless you have the exact replacement; all may be in vain. The other problem, some systems have Controls attached to the speaker box and that is a whole new problem to solve.
The speakers on my gateway computer with windows 8
Do you get any Sound? How about trying a different set of speakers or head phones...do you get sound now? if you do then.. more then likey you blew your new speakers... wouldn't be hard if you had a child playing on your computer that left them turned way up too long... otherwise I would check all the connections including the one on the back of the computer ...If your not getting sound at all no matter what device you try then odds are a windows update installed a different set of drivers for your audio card (I've seen it happen a few times) so you could try to roll back the drivers in the device manager and see if that helps
