20 Most Recent Chauvet Intimidator 1.0 Dmx-600 512 Scanners Questions & Answers
0answers
Intimidator light wont come on
I have 6 of these in my lighting rig, and the most common problem has been a bad bulb socket. If your bulbs end up with corroded or blackened terminals, you should replace the socket. The black/corroded stuff can cause the connection to become intermittent, sometimes so badly it entirely doesn't work. The other common problem I've seen involves a resistor on the circuit board that powers the light bulb. I believe it's R2 - regardless it's the only big one. It's value is .5 ohms at 3 watts. Be sure to use a flameproof resistor when replacing it, and most likely your fixture will light up again.
3/22/2012 3:21:09 PM • Chauvet... • Answered on Mar 22, 2012
Internal fuse blew and is soldered in and I can't
The ratings are normally stamped into the end caps of the fuse. Sometimes they are a bit hard to see. Make sure you repair the cuase of the failure before replacing.
3/20/2011 4:05:30 PM • Chauvet... • Answered on Mar 20, 2011
I have two Chauvet Followspot 400g instruments that won't stop scrolling colors after hooked up to the DMX
Contact the maker for support. It sounds like they are faulty.
11/24/2022 5:57:55 AM • Chauvet Music • Answered on Nov 24, 2022
0answers
My Chauvet Intimidator Spot LED 350 dj lights glitch whenever I DMX them. Why? They work perfect on automatic mode.
Have you got a terminator on the far end? If not this is probably the problem.
4/21/2017 11:55:04 AM • Chauvet Music • Answered on Apr 21, 2017
0answers
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM • Music • Answered on Feb 07, 2024
2answers
FRONTIOPAE what is this instrument unscrambled
'pianoforte'
1/17/2024 4:22:56 PM • Music • Answered on Jan 17, 2024
Looking for specific screw for a Crate and Barrel table
BREV. N. 838420
1/9/2024 8:32:24 PM • Music • Answered on Jan 09, 2024
I want to manually wire my z-560
1/4/2024 1:18:20 PM • Music • Answered on Jan 04, 2024
Electronic drum
See page 22 troubleshooting of this manual. It may help you. dd501 (yamaha.com)
1/3/2024 2:26:52 PM • Music • Answered on Jan 03, 2024
Chauvet Intimidator 1.0 Dmx-600 512 Scanners Logo
6 questions posted
Top Chauvet Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Chauvet Music Expert? Answer questions, earn points and help others
View Most Popular
Chauvet Music
  • Chauvet Music
Most Popular Question
intimidator light wont come
  • Music
