20 Most Recent
Hyundai Sonata 09 2009 Questions & Answers
Why is my 2009 hyundai sonata battery dying after only 3 years?
Hello! First of all, is it a three year battery?...If not,lets check the alternator output...You'll need a multimeter (digital is best)...If you do not have one they can be bought at Lowes or home Depot for under $20...With the key off measure the voltage across the Battery...Example 12 volts...Start the engine...take the reading again...should be 13.9 volts...ie...1.9 volts higher, which means the alternator is working...If all of the above is correct something is remaining on that's draining the battery...most common is the under-hood light remaining on...Lastly, it's just a bad battery that needs replacing...Your vehicle requires a minimum of 600 cranking amps...Send a comment..Guru..saailer I’m happy to help further over the phone at
https://www.6ya.com/expert/david_6df67de3b14de867
Need to know how to replace the rear window brake
Unplug the connector in the trunk.
Remove the 2 gold-colored screws from inside the trunk. They can be seen
from the trunk. One of them is thru the larger square opening where
the wire connects to the high-mount brake light. The second is on the
right side thru a small (screwdriver width) hole covered by a piece of
foam tape.
After removing the 2 screws, go inside the cabin and the brake light housing pops right up.
Disconnect the bulb from the housing while inside the cabin.
Back in the trunk, remove the wire and bulb. The wire from the connector to the bulb socket should be about 5 inches long.good-day !
Po-hm5064h-01
Tengo un estereo de nissan modelo po hm5064h-01 y no tiene la clavija del cableado, como se puede saber en cual pin soldarle los cables
I have recently purchaes Hyundai
This problem seems to be common in Hyundai i20 with AVN sold in India.
My i20 with AVN also has the same problem. The Hyundai dealer is not able to solve this issue. He has replaced the AVN system also, with no luck.
I suggest you contact your dealer to rectify this issue.
regards,
Pradeep
