20 Most Recent RCA Lyra RD2840 MP3 Player Questions & Answers
The answer is maybe. Some devices (remote controls for example) retain memory contents to allow a quick battery change.
RCA Lyra RD2840... | Answered on Dec 21, 2013
Check in ebay.
Also, you can get one in RadioShack. Only confirm the following:
1. AC power adapter with 5V @ 1.5Amps (minimum current, but it may be 2 Amps as well).
2. Plug tip type H
3. The center conductor is the positive contact.
Best regards,
RCA Lyra RD2840... | Answered on Aug 25, 2009
Besides to buy an AC power adapter, you will need to repair the MP3 player too.
The power adapter is cheap in on-line companies (such as Ebay), but still you will need to have serviced your mp3 player.
There are a couple of integrated circuit parts in the battery charging circuitry that are damaged when the impropoer voltage is used.
If you need further assistance to have serviced your mp3 player, after explore different local options, please contact Ebay seller ID Great_tems_2004
Regards,
RCA Lyra RD2840... | Answered on Jul 25, 2009
Just Google the internet with "RD2840 firmware download", download the firmware upgrade .exe file, and follw the instructions in upgrading the firmware of it.
Part of the proces is to restablish all the necessary files.
Best regards,
RCA Lyra RD2840... | Answered on Jul 22, 2009
Unfortunately, the RD2800 Lyra family (RD2825, RD2826 an RD2840) mp3 players have a frequent problem in the battery circuitry, and there are two tiny integrated circuits that are shorted very frequent.
You will need to check the power adapter prior to confirm that the problem is in the RCA mp3 player.
Using a multimeter in DC voltage setting, check the AC power adapter gives a voltage of around 5.0 VDC. If so, then the mp3 player is fried.
The repair involves to opn it, and replace the damaged integrated cicuits. Only a qualified technician with tools and parts cando it.
RCA approved repair centers charge $125.00 for such repair.
If you will look for a cheapest way to fix it, you can contact in ebay to the seller with ID Great_items_2004
Regards,
Regards,
Check the follwing sites:
http://drivers.softpedia.com/get/FIRMWARE/Lyra/
http://www.drivers-software-download.org/tag-download-lyra/
http://www.downloadtube.com/Drivers/Firmware/Lyra/
By the way, the only I did just was Google the internet and look for "RD2840 firmware download"
Best regards,
The battery for Lyra RD2840 is a built in Lithium Ion Polymer Rechargeable Battery. It doesn't say removable as with other MP3 players.I believe, you will need to bring the mp3 player to the manufacturer's service center to have its battery replaced. =(
RCA Lyra RD2840... | Answered on Nov 14, 2008
not inition my display
RCA Lyra RD2840... | Answered on Sep 03, 2008
How do you wipe the memory clean on my RCA Lyra 2840 40 GB Player?
Thanks,
T
RCA Lyra RD2840... | Answered on Aug 05, 2008
Ok often the Battery will take a Looonnnggg time to charge up especially if real flat... Try leaving it overnight.. and see how ya go after it has been charging all night at least 12hours anyway... else try a replacement Battery/Power supply.. Also to test take Batt out, and connect up to the Wall PSU see if that goes if it does then it is just ya Batt.. else it's either ya Power Supply or Motherboard .. Good Luck
RCA Lyra RD2840... | Answered on Jul 29, 2008
Hi, I would suggest that the Battery is faulty.. a common occurrence I have found... Try a brand new or fresh charged know good battery.. I think ya may find thats the culprit.. Also check & clean the Batt Cons inside the unit.
RCA Lyra RD2840... | Answered on Jul 22, 2008
RCA_Lyra_RD2840_MP3_Player - Cord is about 2$ on ebay I'll bet Radio Shack has one....the is also a car charger house charger Batteries already in it!
RCA Lyra RD2840... | Answered on Jun 02, 2008
RCA Lyra RD2840 MP3 Player Logo
Popular Tags
35 questions posted
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
changing battery in rd2780
  • Audio Players & Recorders
