20 Most Recent RCA DRC8005N DVD Recorder Questions & Answers
What DVD disk is formatted to record on this
Any DVD RW should work.If you are having problems,it may be that you do not have a cable box connected?If you do not,it appears that yours may not have a digital tuner which is required to record if there is no digital input such as a cable box.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg
12/8/2010 9:06:38 PM • RCA DRC8005N DVD... • Answered on Dec 08, 2010
Hola tengo un sistema de
Tu usa una cable rojo, blanco y amarillo?
8/3/2010 2:39:56 AM • RCA DRC8005N DVD... • Answered on Aug 03, 2010
I am looking for rca drc8005n manual
Press and hold STANDBY/ON while holding STOP for 3 seconds this will reinitialize the unit but did not solve my issue
1/14/2010 11:55:18 PM • RCA DRC8005N DVD... • Answered on Jan 14, 2010
2answers
Can't Record, wont read blank DVD
Have the same problem with this piece of junk.
Tried all the solutions. Clean lens etc. Nothing helped.
Tried replacing the drive with another that I had. No go, apparently has some proprietary firmware.
I was about to throw it in the trash when I suddenly realized that it had a TV tuner. Hooked it up to my computer through a Pinnacle Dazzle interface and VOILA I had a hard drive recorder. I either just watch it on my monitor or burn a DVD if it is something I want to keep. Hey that is better than pitching something you paid $300 bucks for in the trash. You can pick up a dazzle or similar on EBAY for a lot less than a new Hard disc recorder will cost you.
9/3/2009 12:40:55 AM • RCA DRC8005N DVD... • Answered on Sep 03, 2009
RCA DRC8005N Will not finalize discs
well the problem is that the machine are not closing the dvds, you say you go step by step, but it realy is not closing the disc, it can play the not close dvd, but you cant play in a regular dvd player, I dont think is a cleaner problem, but try any way, blow dry air by the dvd port, and see, if not you got a damage one...god luck
8/11/2006 2:59:26 AM • RCA DRC8005N DVD... • Answered on Aug 11, 2006
DVD recorder will not record
Sounds like the slider assy., tracking motor, or the rail is gunked up. If you know how to disassemble the slider by all means take apart ans see if theres any dirt or hair tangled inside the gears or track. If you dont, you should let a tech take a look at it, as if you take something apart that shouldnt have been disassembled, it will cost ya double to repair. Also the tech will have all the proper alighnment tools and disc to properly get the unit back up and running. Not alot a consumer can do nowadays to repair solid state electronics! Good Luck
6/26/2006 1:44:48 PM • RCA DRC8005N DVD... • Answered on Jun 26, 2006
DVD recorder won'r record
Have you tryed the obvious? Cleanning the lens ? Now sometimes you have to unplug the unit and take off the top cover and take a cotton swab and apply a smidge of alcohal Just a drop and slighty clean the lens very carefully. thgen make sure you let itr dry well. Good Luck
6/5/2006 12:20:53 AM • RCA DRC8005N DVD... • Answered on Jun 05, 2006
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
2answers
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them. Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
2/2/2024 11:35:38 PM • RCA Televison &... • Answered on Feb 02, 2024
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse . TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
1/21/2024 8:13:40 PM • RCA Televison &... • Answered on Jan 21, 2024
What is the code for remote control for RCA model# RT 1971-AC
Better idea https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com https://www.amazon.com > Replacement-DETG160R-... Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control. US$32.99 · ‎In stock
RCA RT1971AC Replacement Remote
Remotes.net https://www.remotes.net > products > replacement-rem... If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems. US$34.90 RCA Universal Remote Codes:
  • The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
  • The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
  • The cable box codes are: 000 and 027.
Apr 26, 2023
RCA Universal Remote Codes List 4 Digit - GenTwenty
12/27/2023 12:47:10 AM • RCA Televison &... • Answered on Dec 27, 2023
Rca remote r26211 code for trutech tv dvd
Better to get a Facsimile Remote, a copy made for the unit. It is unlikely, you can input codes to work both applications in a combined set.
TruTech TV universal remote control codes (3, 4 and 5 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > trutec... Universal remote codes for TruTech TV sets - 3 digit, 4 digit and 5 digit codes.
My mom has a Trutech combination TV/DVD, about 20 ...
JustAnswer http://www.justanswer.com > TV Problems Feb 6, 2013 - There are very few universal remotes that will operate a tv/dvd combo and of ten if you find a code then the tv a dvd have separate codes. 1 answer · Top answer: Jack : Hi and welcome to justanswer. To answer your question; There are Make sure you use the FULL Model Number for it.
TRUTECH TV Replacement Remote
Remotes.com https://www.remotes.com > trutech-remote-controls-s Replace new & discontinued remote controls for TRUTECH devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Trutech Remote for sale
eBay https://www.ebay.com > ... > Remote Controls Sort ; 2PCS Remote Control For TruTech KLV3170 LCD Drop Down TV Built-in DVD Player · $13.83 ; TruTech A60P0315 Remote Control Genuine OEM TESTED · $3.00 ; Original ...
Trutech Remote Control
Amazon https://www.amazon.com > trutech-remote-control > k... GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, TCL, Panasonic, Smart TVs, Streaming Players, Blu-ray, DVD, 4-Device, ...
12/20/2023 1:17:20 AM • RCA Televison &... • Answered on Dec 20, 2023
I dropped my RCA remote control, how can I reestablish connection with Magnovox tv?
Check that the batteries haven't become disconnected. Do the Smartphone camera test to see if it is transmitting a signal. If it isn't, buy a remotes specially made for the Magnavox rather than an RCA Universal. Google Magnavox (model) remote control replacement. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
11/30/2023 4:26:09 PM • RCA Televison &... • Answered on Nov 30, 2023
My old Panasonic TV set has no video RCA slot. Only audio R and L slot available.
tv is not a smart tv, may have to replace it.
11/27/2023 3:30:48 PM • RCA Televison &... • Answered on Nov 27, 2023
RCA DRC8005N DVD Recorder Logo
14 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
dvd disk formatted record
  • Televison & Video
