20 Most Recent RCA DVR-40 DirecTV DTV Receiver / 35-Hours Video Recorder Questions & Answers
Need a service manual with
I don't think the service manual is available for these units since they have DirecTv built into them
7/27/2011 12:03:10 AM • RCA DVR-40... • Answered on Jul 27, 2011
3answers
RCA DVR-40 Directv receiver will not make a call to Directv
i believe you have to slow the modem speed down. contact directv 800-531-5000 on instructions how to slow the modem speed. tell them you are getting "service not answering" hope this helps!
1/21/2011 5:15:07 AM • RCA DVR-40... • Answered on Jan 21, 2011
Dvr won't turn on but fan is running
If you unplug the dvr and open it up, unscrew the screws and just open the casing. Can you see any battery inside it? It would look similar to a watch battery most likely. My security dvr will do that and I have to replace the internal battery, not sure if tivo like dvrs are the same though.
7/28/2010 1:17:04 AM • RCA DVR-40... • Answered on Jul 28, 2010
2answers
Copy stored programs
If you have your unit hacked, then you can use tytool to copy the programs to your computer. This will only work for programs that are recorded once the unit is hacked. Do a search for the zipper for series2 dtivos.
3/21/2009 11:53:26 PM • RCA DVR-40... • Answered on Mar 21, 2009
Fan runs, no panel lights, no response to remote
replaced the older receiver box and had Directv reactivate the card. Will probably find another one later.
2/20/2009 5:58:41 PM • RCA DVR-40... • Answered on Feb 20, 2009
DVR Freezing up
Most likely it's your hard drive going bad. You can replace it and not junk the unit.
12/1/2007 4:46:40 PM • RCA DVR-40... • Answered on Dec 01, 2007
RCA Directv DVR
For all intents and purposes, your receiver is identical to the Direct TV R-10 (which is also made by RCA). There are TWO POSSIBLE SCENARIOS AND TWO POSSIBLE SOLUTIONS. PLEASE READ BOTH FIRST: Scenario #1 (Applies to 90% of situations) If this is a software issue: There are a number of software issues related to this receiver that Direct TV software engineers have been working on. If the receiver worked well before and then started running slowly unexpectedly, I would lean toward thinking that DirecTV downloaded a software patch that didn't take on your receiver. I would pull up the systems information screen and copy down all information especially the software version number and call DTV technical support to find out if you have the correct software version for your particular machine. There are a few minor difference between yours and an R-10 (like Hard Drive size and memory)which, in a rare case, might cause this problem. TiVo's use the Linux Operating System. A wrong kernel version, or software module can bog everything down. Be aware also, if they cannot fix it by resending and reauthorizing your receiver, the next step would be to do a hard restart. This is the setting in the menu "erase everything" which reformats (re-initializes the drive) You will receive a screen message which says this could take up to an hour (in some rare cases 2) The hard restart/reinitialing will erase all of your recordings and settings. If this doesn't fix the "slow" problem,(you will be able to tell after 3 or 4 days of use) Direct TV will offer to send you a replacement R-10 (which is also TiVo; you pay only the shipping of $19.95 and in some cases they waive that. Scenario #2 (Applies to 10% of situations) Hardware issue. If it can be validated that the correct software version is installed and all systems settings have been reset, reauthorized, and tried without positive results, then this may apply: DVR's save and store programs on a computer Hard Disk Drive. It is possible that slow reaction and response from your DVR is also an early warning sign of a Hard Drive that is beginning to fail and encountering errors and slow data storage (your shows and movies) and recovery. If this is the case, then a new replacement hard drive would be in order (only if you own the receiver and it is not leased) It is easiest to order replacement hard drives off the internet. You can't replace them with just any drive, however. The drive needs to have the Linux OS with the TiVo software kernel installed first and pre-initialized. You can have a professional do it for you or if you are electronically inclined, you can replace the hard drive yourself. Replacement drives normally have instructions included giving you step by step procedures for removing the old and installing the new drive. I order TiVo drives from www.weaknees.com. They are a known and reputable supplier of pre configured Maxtor Hard Drives which are specially designed for Home DVR's (I only recommend Maxtor or Seagate brand Hard Drives and these Maxtors are of special high quality). You may have to get an upgrade to an 70 hour (80GB)drive since your 40GB (35 hour) is harder to find and quite possibly no longer in production or available. If you want, you can send your receiver to weaknees and they can professionally install and configure everything for you. (Weaknees is located in Los Angeles, Ca) I have no interest in them, but I am satisfied that they know what they are doing. I hope this information helps you. Good Luck and best regards, Eric,
3/2/2007 7:26:10 PM • RCA DVR-40... • Answered on Mar 02, 2007
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
2answers
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them. Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
2/2/2024 11:35:38 PM • RCA Televison &... • Answered on Feb 02, 2024
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse . TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
1/21/2024 8:13:40 PM • RCA Televison &... • Answered on Jan 21, 2024
What is the code for remote control for RCA model# RT 1971-AC
Better idea https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com https://www.amazon.com > Replacement-DETG160R-... Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control. US$32.99 · ‎In stock
RCA RT1971AC Replacement Remote
Remotes.net https://www.remotes.net > products > replacement-rem... If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems. US$34.90 RCA Universal Remote Codes:
  • The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
  • The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
  • The cable box codes are: 000 and 027.
Apr 26, 2023
RCA Universal Remote Codes List 4 Digit - GenTwenty
12/27/2023 12:47:10 AM • RCA Televison &... • Answered on Dec 27, 2023
Rca remote r26211 code for trutech tv dvd
Better to get a Facsimile Remote, a copy made for the unit. It is unlikely, you can input codes to work both applications in a combined set.
TruTech TV universal remote control codes (3, 4 and 5 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > trutec... Universal remote codes for TruTech TV sets - 3 digit, 4 digit and 5 digit codes.
My mom has a Trutech combination TV/DVD, about 20 ...
JustAnswer http://www.justanswer.com > TV Problems Feb 6, 2013 - There are very few universal remotes that will operate a tv/dvd combo and of ten if you find a code then the tv a dvd have separate codes. 1 answer · Top answer: Jack : Hi and welcome to justanswer. To answer your question; There are Make sure you use the FULL Model Number for it.
TRUTECH TV Replacement Remote
Remotes.com https://www.remotes.com > trutech-remote-controls-s Replace new & discontinued remote controls for TRUTECH devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Trutech Remote for sale
eBay https://www.ebay.com > ... > Remote Controls Sort ; 2PCS Remote Control For TruTech KLV3170 LCD Drop Down TV Built-in DVD Player · $13.83 ; TruTech A60P0315 Remote Control Genuine OEM TESTED · $3.00 ; Original ...
Trutech Remote Control
Amazon https://www.amazon.com > trutech-remote-control > k... GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, TCL, Panasonic, Smart TVs, Streaming Players, Blu-ray, DVD, 4-Device, ...
12/20/2023 1:17:20 AM • RCA Televison &... • Answered on Dec 20, 2023
I dropped my RCA remote control, how can I reestablish connection with Magnovox tv?
Check that the batteries haven't become disconnected. Do the Smartphone camera test to see if it is transmitting a signal. If it isn't, buy a remotes specially made for the Magnavox rather than an RCA Universal. Google Magnavox (model) remote control replacement. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
11/30/2023 4:26:09 PM • RCA Televison &... • Answered on Nov 30, 2023
My old Panasonic TV set has no video RCA slot. Only audio R and L slot available.
tv is not a smart tv, may have to replace it.
11/27/2023 3:30:48 PM • RCA Televison &... • Answered on Nov 27, 2023
How do I program an RCA TV with a Panasonic universal remote control e u r 7722x40
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote RCA Universal Remote Codes: For the RCA Universal Remote, there is a total eight different codes for RCA TV's and nine for VCR's. There are two different codes for cable boxes:
11/19/2023 5:44:36 AM • RCA Televison &... • Answered on Nov 19, 2023
Will RCA DRC8335 finalize discs recorded on RCA DRC8312 ?
Depends on the software you are using; ExpressBurn, Movavi etc will finalize.
11/13/2023 5:50:11 PM • RCA Televison &... • Answered on Nov 13, 2023
RCA DVR-40 DirecTV DTV Receiver / 35-Hours Video Recorder Logo
11 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
dvr turn but fan running
  • Televison & Video
