20 Most Recent RCA P56923BL 56" Rear Projection Television Questions & Answers
2answers
Will not turn on
See my tip at http://www.fixya.com/support/r4916941-diagnose_repair_projection_tv_high for help solving your problem.
Thanks for using FixYa and for the great rating.
hardrocko
8/16/2011 1:27:42 AM • RCA P56923BL 56"... • Answered on Aug 16, 2011
Picture looks like 3d i have ajusted screen but
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
8/28/2010 4:07:02 AM • RCA P56923BL 56"... • Answered on Aug 28, 2010
Tv will not turn on
always first unplug set and let sit 10 to 20 minutes to reset micro prossessor. if that don't help then you need to have an electronic technition determine if your problem is caused by high voltage devider or low voltage power supply. J.D.W.
6/25/2010 2:22:59 AM • RCA P56923BL 56"... • Answered on Jun 25, 2010
Mistubishi Convergence/video display problem
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
4/18/2010 1:46:43 AM • RCA P56923BL 56"... • Answered on Apr 18, 2010
Bowed out picture on rca projection tv
This unit has a problem in the pincushion correction circuit. These sets are famous for loose solder connections causing this problem. The Deflection PCB will have to be removed to repair this. You may want to contact a repair shop to help you out. Thanks
10/29/2009 3:03:26 PM • RCA P56923BL 56"... • Answered on Oct 29, 2009
2answers
TV is just beeping no picture/sound
I have looked through most of the answers to the same problem question and found my answer. I thank you very much for your site for the free info as the cost could have been huge to fix it. Now that I no the part the cost is minimal, and I can do it myself(with a little help from my friends).
Again Thank You
Kim Graziano
9/8/2009 12:33:38 PM • RCA P56923BL 56"... • Answered on Sep 08, 2009
Picture does not show and power goes off.
There is a capacitor that started out with a bad solder conection and is now burning the board. This capacitor should be replaced.
7/8/2009 9:29:09 PM • RCA P56923BL 56"... • Answered on Jul 08, 2009
How hard would it be to replace a bad flyback and
replacing the fly-back itself is not enough. you need to check the components surrounding the transformer, whether the fet isn't shorted and the diode is ok.
4/24/2009 9:18:53 PM • RCA P56923BL 56"... • Answered on Apr 24, 2009
High Screen
resolder FBT PINNS
2/13/2009 10:50:23 PM • RCA P56923BL 56"... • Answered on Feb 13, 2009
Mitsubishi WS-48311horizontal scroll
Its not a problem you can easily fix. Many Mits TVs of the mid-90's had a PIP board in them that had dried up surface mount capacitors on them. The board would have to be either re-built or replaced at a considerable cost.
michtech
2/13/2009 5:29:16 PM • RCA P56923BL 56"... • Answered on Feb 13, 2009
RCA D52W26 rear projection. 2 years old. 3 times and powers out.
Try replacing CP150, CP114 and CP120 first cost about 12.00 with free instructions available at the following link under the RCA parts category
http://servicemanuals.vstore.ca/
2/10/2009 4:51:50 PM • RCA P56923BL 56"... • Answered on Feb 10, 2009
2answers
Convergence problem
If the convergence is out on that set you most likely do not need to make an adjustment the circuit will need to be repaired. There is a stk on the convergence amp board that needs to be replaced. A good tv shop will run you somewhere between $300-$500 to do the repair
2/10/2009 2:58:38 AM • RCA P56923BL 56"... • Answered on Feb 10, 2009
CHERPING AND NOT COMING ON ON AN P56923BL
the transister is a bad one...
12/6/2008 9:42:44 PM • RCA P56923BL 56"... • Answered on Dec 06, 2008
Rca p56923bl chirping
Horizontal Output transistor looks like this attached to a heat sink near the Flyback transformer97bd027.jpg
12/6/2008 1:23:03 AM • RCA P56923BL 56"... • Answered on Dec 06, 2008
RCA-Churping Noise
it needs horizontal supply repaired and all will be well....
7/7/2008 2:23:04 AM • RCA P56923BL 56"... • Answered on Jul 07, 2008
Where is the convergence control?
Unplug the set wait five minutes then try again go to menu where closed caption is............
12/3/2007 9:26:13 PM • RCA P56923BL 56"... • Answered on Dec 03, 2007
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
Televison & Video Logo
21 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
mistubishi convergence video display
  • Televison & Video
