20 Most Recent NCR 7875 Questions & Answers
With our Scanner NCR7875 , we have problem with all EAN 13 digit barcode . its give starts with F and then barcode . like F123456789123. what to do ?
It seems like you have a suffix set on reading. You should download settings manual, i'll guide you when you do that
6/13/2019 2:33:19 AM • NCR 7875 • Answered on Jun 13, 2019
2answers
NCR scanner scale 7875 communicating with pc
You would need a PC to communicate it with. Either Via USB or the DataRX port.
Capital Computer Group, LLC
651-405-8293
www.capcom-ncr.com
We specialize in the NCR arena, also have many other point of sale needs.
Free bench testing equipment failure on any p.o.s hardware item.
7/21/2014 9:52:40 PM • NCR 7875 • Answered on Jul 21, 2014
2answers
I need the software to operate my NCR 7875-2000.
go to the makers website
5/28/2013 6:28:31 AM • NCR 7875 • Answered on May 28, 2013
Enabling NCR 7875 flatbed scanner to read Code 128 barcodes
On a 7876, you need to scan the sequence “17130” is to add 128 tag readability. Not too sure if the 7875 is the same.
12/21/2012 12:18:18 AM • NCR 7875 • Answered on Dec 21, 2012
2answers
Programming scale to display in pounds
ITS YOUR SCALE BOARD! <-- I am also an NCR Technician (Now Sales and Technician)
2425 Enterprise Dr.
#200
Mendota Heights MN, 55120
[email protected]
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR, IBM... We also offer structured cabling as well as Video Surveillance Equipment.
Give us a call and we can trouble shoot it with you!
8/4/2012 8:25:33 AM • NCR 7875 • Answered on Aug 04, 2012
3answers
NCR 7875 Scanner/Scale Communication problem with PC
You need another cable (the metrologic cable doesnt work with the same configuration) and set the button in the interface card to rs-232 and program the scanner-scale with the programing tags.
6/16/2012 2:57:39 PM • NCR 7875 • Answered on Jun 16, 2012
I need USB drivers to allow communication between
Hi there,First I'd like to thank you for selecting my services. I've located the software for your NRC Scanner scale 7875. You can obtain firmware and related tools from http://www5.ncr.com/support/support_drivers_patches.asp?Class=retail_RealScanAs for the windows drivers they are available for you here http://www.digi.com/support/productdetl.jsp?pid=2628&osvid=57&tp=1&s=0&tp2=0Select windows xp from the drop down list and then the 4002537_h is the one your looking for, version 5.3I'll send a copy to your email address.Let me know if you need further assistance.Thanks,Ekse (Niko Ohtonen)
10/7/2011 10:20:20 PM • NCR 7875 • Answered on Oct 07, 2011
I need to change an NCR 7875 - 2000 from lbs to kg
Firstly you will need NCR Scan Tags. You can download from
http://ncrpr.ncr.com/web/rsdmkt/dealerReady/docs/User_Guides/HighPer_Scanner-User-Guide.pdf
You will have to print out the Scan Tags which start at page 281 and you will also need the correct weights; 0kg, 2.5kg, 5kg and 10kg.
Then follow these steps and be sure to scan tags in correct order:
1. Reset
2. Default
3. Program mode
4. Hex 3
5. Hex 0
6. Hex 1
7. Push the calibrate button under weighing tray
8. Place the correct weights in order. It will ask for the weights in order.
9. Calibration complete
2/24/2011 12:05:02 AM • NCR 7875 • Answered on Feb 24, 2011
3answers
I am looking for a ncr keyboard wedge cable for
Go to this LINK
12/26/2010 10:07:09 PM • NCR 7875 • Answered on Dec 26, 2010
2answers
MANUAL CALIBRATION SCALE SCANNER NCR 7875
codigos de barra para configurar scaner 7875-2000
9/5/2010 8:40:11 PM • NCR 7875 • Answered on Sep 05, 2010
4answers
My problem is that I
click this link direcrtly
http://www.alsys.ro/soft/doc/7875Bi-OpticAggressiveReadScanner-Scale.pdf
also click this link directly for more help
http://www.encore.com.tr/docs/realscan_7875/sa_7875.pdf
thanks.keep updated.
8/9/2010 12:56:49 PM • NCR 7875 • Answered on Aug 09, 2010
651-405-8293
www.capcom-ncr.com
4/22/2010 7:23:50 PM • NCR 7875 • Answered on Apr 22, 2010
Ncr Scanner 7875-2000
Hmmmm.... It sounds as though your scanner is not programmed correctly. Either RS232 or IBM... Either way it sounds as though it is not accepting your communication entry. Which could be your Eeprom chip, a digital board, maybe even the dual I/O board, in most cases.
651-405-8293
www.capcom-ncr.com
4/22/2010 6:56:07 PM • NCR 7875 • Answered on Apr 22, 2010
I need to find the power requirement info for an
The power supply for a 7875-2XXX series
PN: 497-0435538
input: 100V-250V
Output: +/- 5V -- 1.5A
-12 v --- 0.3 a
651-405-8293
www.capcom-ncr.com
4/22/2010 6:52:35 PM • NCR 7875 • Answered on Apr 22, 2010
3answers
7875 scanner/scale error code 4.
Problem is with the scale part of theunit, it needs calibrating, you can do this but you do need a set of weights, and it also depends on what country you are in reference the legality after you have done this. But chack fist the top plate is OK not damaged and sits OK, press scale zero. If that does not work there is a cover at the front of the unit sometimes with a seal over it or through the part that stops the cover being shown. Press the button under thisand follow the audio instructions, you will need 2.5kg, 5kg & 10kg or 5lb, 15lb & 30lb depending on ncountry you may need Weights & Measures in to verify afterwords depending on legalities
4/22/2010 6:12:26 PM • NCR 7875 • Answered on Apr 22, 2010
I know there is a set of bar codes you can scan on the NCR 7875
Yes sir, I think NCR refers to them as "hex tags" but anyways one of the hex tags is labeled "Diagnostic" I think that is the one that will tell you the current settings. I found the tags on the manual for a different model (pages 282-296 on the pdf in the first link). After you get the tags printed from this link just use the manual for 7875 (second link) model to know what sequence to scan these tags good luck! http://ncrpr.ncr.com/web/rsdmkt/dealerReady/docs/User_Guides/HighPer_Scanner-User-Guide.pdf
https://docs.symbol.com/manuals/3765801a.pdf
4/21/2010 8:01:53 AM • NCR 7875 • Answered on Apr 21, 2010
Computers & Internet Logo
46 questions posted
Top NCR Computers & Internet Experts
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
YONATAN
YONATAN
Level 1 Expert
Are you a NCR Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NCR Computers & Internet
Most Popular Question
need change ncr 7875 2000 from lbs kg
  • Computers & Internet
