20 Most Recent
Broksonic CTSGT8118T 13 in. TV/VCR Combo Questions & Answers
How do I turn the Closed Captioning on?
Try and hold both volume up channel up at the same time for at least 5 seconds and hope that the menu will come up. Use the channel arrows to select your choices.
If that doesn't work, try channel down volume down as your combo.
10/30/2013 6:28:48 PM •
Broksonic...
Answered
on Oct 30, 2013
Orig. remote wore out. Can't get a universal
Hello
have you checked with these codes with it:
Three digit universal remote code for Broksonic are:-
136/ 147
Four digit universal remote code for Broksonic are:-
0147 0135 0250
0257 0310 0394
Proceedings
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Just switch On and Off the TV with its power switch on the front panel [NOT BY THE REMOTE CONTROL HANSET] before trying an other code.
ok.
12/20/2010 3:46:20 PM •
Broksonic...
Answered
on Dec 20, 2010
Need help with taking off
Look on you remote for a button labeled CC keep hitting this button until it says CC off on the screen, if no button on your remote then select menu on the television and look for Closed caption option and set to off posistion.
6/28/2010 3:14:30 PM •
Broksonic...
Answered
on Jun 28, 2010
Searce for channels without remote
You have to search for channels with the menu. If there is a menu button on the TV, you are in business. If not, you can try one of the more sophisticated universal remotes, but most do not run the menu functions...
This link says they can get Broksonic parts:
http://www.acme-sales.net
I've dealt with this company:
www.encompassparts.com/.../Broksonic_Consumer_Electronics_Parts_and_Accessories.asp
3/28/2010 11:11:54 PM •
Broksonic...
Answered
on Mar 28, 2010
Forgot password on broksonic tv
Hi
Thanks for using FixYa. Try these codes for your Broksonic---
10236,10463,11911,11938, 10030, 11935, 11929
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
11/17/2009 5:17:11 PM •
Broksonic...
Answered
on Nov 17, 2009
